Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Jan 6, 2021 at 3:38 PM
    #41
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Don’t forget the warranty differed if you had a dealer do it or you DIY’d it.
  2. Jan 6, 2021 at 3:40 PM
    #42
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    True, but it's the same warranty I was told many times over when installing TRD parts on my car. They can say you installed it wrong.
    Boyettexan likes this.
  3. Jan 6, 2021 at 3:46 PM
    #43
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    It would be super cool if they offered several factory leaf options similar to the icon rxt pack. Stouter options for people who are going to load it up with gear right away and a base option that rides where stock Tacoma’s do now.
  4. Jan 6, 2021 at 3:51 PM
    #44
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Fair point, when you buy the parts and DIY, you get a parts warranty only. Dealer install gets you warranty on faulty install as well as labor to replace faulty parts.
    Questions to those with experience, I wonder if you could DIY and pay the dealer a few bucks to inspect it, get an official service record documenting it was installed correctly.
    Boyettexan and stevesnj[QUOTED] like this.
  5. Jan 6, 2021 at 3:54 PM
    #45
    stevesnj
    I asked that too...lol They told me they can look (visual inspection) at it for a fee but won't give the better warranty since they don't know if the torque is right on the bolts etc. Something they record they did to ensure the better warranty.
    mattleg[QUOTED] likes this.
  6. Jan 6, 2021 at 4:14 PM
    #46
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    I would be OK without a labor warranty on the lift itself, just looking to avoid them not honoring warranty on other parts, say a CV or front differential, by trying to blame it on an improperly installed OEM lift.
    The whole torque thing is amusing, they don't record that, lucky if they even bothered to torque at all.
  7. Jan 6, 2021 at 4:23 PM
    #47
    stevesnj
    Very true. yes. I installed lowering springs on my Toyota 86, they told me that the part is covered but if that part damages another warrantied (non TRD) part because of improper install then the affected part won't be covered. If they installed it improperly then the part it damaged would be covered.
    BTH1 and mattleg[QUOTED] like this.
  8. Jan 6, 2021 at 4:43 PM
    #48
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    With the supercharger they gave you the full factory powertrain warranty whereas if you DIY’d it, you didn’t get that.
    I like the idea of an OEM kit because in theory it should be higher quality than aftermarket and fit better, but who knows.
    That (and the price) was a driving factor for my 2G Pro kit. I threw it in myself because I knew I could do it just as good as a dealer tech and I wasn’t terribly worried about my warranty. My dealer replaced my 2G transmission post-lift.
    mattleg and stevesnj[QUOTED] like this.
  9. Jan 6, 2021 at 5:51 PM
    #49
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    I like the idea of this kit too, not just for the presumed OEM quality, but also what should the engineering of it - including the efforts they invested to validate TSS functions. I would guess TSS is why the DCLB is excluded.
    It's interesting to consider, and understandable why it may have taken so long to release, this kit would put an SR on the road with a 1-inch lift over the Pro, with the Pro grille as well, straight from a dealer new.
    Lowkey likes this.
  10. Jan 6, 2021 at 5:54 PM
    #50
    stevesnj
    I think the R and D they put into TRD line is very good. The TRD items I put on my car were well made, performed as advertised and had great install instructions. I think TRD is a very good option for some.
  11. Jan 6, 2021 at 6:00 PM
    #51
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    I wonder why the need for the fog light replacement covers. Does Toyota suggest removing the fog lights as part of the installation of the kit?
    Also with a separate part number for the shocks and struts they could be purchased without the rest of the kit.
  12. Jan 6, 2021 at 6:04 PM
    #52
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You misunderstood. The base $510 kit just includes "small parts" - U-bolts, fog light blanking plates, and leaf spacers :rofl: You still need to buy the Pro grille, shocks, and new radar separately...
    BRBNNEAT and Barsoom like this.
  13. Jan 6, 2021 at 6:08 PM
    #53
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Welcome to the baggage of OEM certification. Being port-installed means it has to meet new-vehicle mfg regulations. The lift probably causes the OEM fog light beam pattern to violate SAE J583. (The Pro probably gets around this with the different Rigid fog lights.)
  14. Jan 6, 2021 at 7:35 PM
    #54
    NomadicCypress
    NomadicCypress Well-Known Member
    2023 Solar Octane TRD Pro M/T
    Sorry if this is a dumb question but does the pro grille/new sensor have to be installed in order to work properly due to the extra height or could one just buy the lift parts and leave the stock grille and sensors and not have any issue?
  15. Jan 6, 2021 at 7:43 PM
    #55
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Stock grille and sensors will work OK most of the time, like people have been doing for the past 3 years...
    I'm lifted 2.7" up front, with the sensor moved up another 0.4" with the 2020 grille swap, and get no errors with TSS or adaptive cruise. This is not to say TSS will perform to OEM specifications. It's possible the pre-collision warning will trigger at a different distance, miss pedestrians below a certain height, etc.
  16. Jan 7, 2021 at 5:18 AM
    #56
    Brushog65
    Brushog65 Well-Known Member
    2021 Trd off road
    Called my dealership this morning and was told installed was$2600. I was told 3 hours of that was set up of the front sensor. Even if I installed everything I would still have to take it there to have the sensor set up.
  17. Jan 7, 2021 at 8:31 AM
    #57
    Tatanka
    Tatanka Well-Known Member
    Pennsylvania
    2014 DCLB TRD
    About $2500 installed.
  18. Jan 10, 2021 at 3:28 PM
    #58
    Brushog65
    2021 Trd off road
    I put the trd lift in my truck this weekend. Can’t decide if the front is higher than the back. May go back in and lower one notch on the front shock. What do you guys think? 36A76434-E8F5-4F67-8241-847B839A755D.jpgE25271C6-CE53-488A-A05C-2CB237FD3F47.jpg
  19. Jan 10, 2021 at 4:41 PM
    #59
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    The top picture looks a little nose high, but the second looks level. Hard to tell though. How’s the ride quality?
  20. Jan 10, 2021 at 4:43 PM
    #60
    Brushog65
    2021 Trd off road
    Ride quality is great. I can’t really tell any difference from stock.
    GoyoGreybeard and Oatwillie like this.
