Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Apr 2, 2021 at 7:34 AM
    #781
    RCrumb
    RCrumb Dumb as Dirt
    CANADA
    2020 TRD OR Premium-Auto
    Just an FYI, apologies if this has been posted already. On the Toyota Canada website when you build a Taco the TRD lift kit is an option you can now pick, with an installed price. Dont see it on the US site.
    Enjoy
  2. Apr 2, 2021 at 12:36 PM
    #782
    N3FOLMike
    N3FOLMike Well-Known Member
    2021 Tacoma TRD OffRoad
    Some say with 285 tire it will rub. That is a ‘No’. It will not rub. I have the TRD lift kit installed on 285 KO2. I love the ride. Smooth. No complaints so far. After a couple of weeks from install, dealer wanted to check the suspension for retorque. All good. Whatever size tire you decide, it will look good as long as you are happy with it.
  3. Apr 2, 2021 at 12:39 PM
    #783
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Every truck is different
    jeremy5000, FLJB and Fast1 like this.
  4. Apr 2, 2021 at 12:46 PM
    #784
    bolt_thrower77
    bolt_thrower77 Well-Known Member
    2021 DCLB trd or
    hey all.....i've got my shocks.....waiting on a 1.25 rear block to be shipped for install......to be clear....this uses the factory springs up front?.....they don't mind being stretched out an extra 2"?.....and also.....i've asked this question before but can't seem to get a good answer......if i do the front diff drop to correct the cv angles, will this help to avoid the dreaded needle bearing issue?..... thanks for any advice.... :)
  5. Apr 2, 2021 at 12:59 PM
    #785
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Agree and so are 285 tires.. all are slightly different in width and rolling diameter
    Might as well add wheels too.. width, offset etc.. all fit differently
    Then many that have tested different tires have yet to exercise the TRD suspension besides riding down the highway to get the coils to settle from install ride height.. They need some rough dirt roads to actuate the suspension and to get to the ride height they will end up at an accelerated pace vs just pounding pavement.
  6. Apr 2, 2021 at 1:06 PM
    #786
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Exactly all are different
    Fast1[QUOTED] likes this.
  7. Apr 2, 2021 at 2:30 PM
    #787
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    The Springs do not get stretched more, they get compressed more.
    71tattooguy likes this.
  8. Apr 2, 2021 at 7:02 PM
    #788
    bolt_thrower77
    2021 DCLB trd or
    oh....i assumed that the shock was longer and gave the lift and may or may not need longer spring to accommodate....like taller vehicle would need taller shock/spring..... either way, i suppose i don't need new springs.....no thoughts on the diff drop to correct cv angle and avoid needle bearing?....thanks again for schooling me on this....i've never lifted a truck
  9. Apr 3, 2021 at 5:02 AM
    #789
    N3FOLMike
    Glad you guys pointed that out. Not all trucks are the same and not all trucks hit the dirt roads all the time. FWIW, the kit looks good on a 2021 TRD OR and it has its benefits. I’ll share my experience to help other guys decide what kind of build and how much $ is required to make it happen.
    Select your build design carefully based on your plans and intention on what you want to do with your truck. This is what makes it fun...there is a lot of aftermarket parts and accessories available for the Taco.
    OG_Tacoma likes this.
  10. Apr 3, 2021 at 5:08 AM
    #790
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Toyota Dealers have a special Toyota Certified spring stretcher in all their shops. It's a not issue and backed by oem warranty.
    Spare Parts and N3FOLMike like this.
  11. Apr 3, 2021 at 5:30 AM
    #791
    Shades_Of_Red
    Lou
    Pittsburgh, PA
    A few.
    The Diff drop seems to be a matter of personal preference. In my opinion a lift of 2 inches or under doesnt need it.
    Are u installing the kit urself?
  12. Apr 3, 2021 at 3:14 PM
    #792
    SkyDivinTaco
    SkyDivinTaco Well-Known Member
    T.
    Oahu
    Silver 2004 OR Taco & Voodoo Blue 2021 OR Taco
    For those of you having the ECGS Clamshell installed, is the dealership actually doing this in tandem with the OEM lift install? If so, did you have to pre-coordinate this non-Toyota part install? Asking, because I don't think I've every heard of a dealership installing non-OEM, let alone customer provided parts. Please share your story and/or approach to convincing Service Dept. to install. I'd like to explore this route, but haven't yet approached service manager. Hell, it makes sense for them to avoid later issues by installing Clamshell, but often times, common sense doesn't prevail.
  13. Apr 3, 2021 at 3:29 PM
    #793
    TacoOggie
    TacoOggie Active Member
    Og
    2020 QS TRD Sport
    My dealer actually recommended it. They install them as standard practice when they do lifts. They told me when I bought the truck from them "If you get this lifted somewhere else, make sure they add the ECGS Clamshell bushing. A lot of people don't but we do."
    The bushing was included without me even asking but I doubt all dealers do the same.
  14. Apr 4, 2021 at 12:40 PM
    #794
    SkyDivinTaco
    T.
    Oahu
    Good deal and congrats Oggie. Your Dealership/Service Dept. sounds like a unicorn. I'm still going to do my best to try and persuade my dealership to include Clamshell.
  15. Apr 4, 2021 at 1:08 PM
    #795
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    Which dealership is this? Thanks.
  16. Apr 4, 2021 at 3:20 PM
    #796
    Tacobelt
    Tacobelt Well-Known Member
    2016 TRD Sport AC 6MT
    I’m extremely confident I can install the rear shocks myself. The front shocks my be a different story. The Deaver aal seems like a great option.
  17. Apr 4, 2021 at 3:28 PM
    #797
    TacoOggie
    Og
    2020 QS TRD Sport
    Tony Divino Toyota, Riverdale Utah.
    HOF Taco, rubiconjp[QUOTED] and Fast1 like this.
  18. Apr 5, 2021 at 8:42 AM
    #798
    turkeycreek29010
    turkeycreek29010 Well-Known Member
    Chuck
    Bishopville, SC
    2021 TRD Offroad
    TRD Lift, MKW Offroad M205 Bronze 17 x8.5 wheels, 265/70r17 General Grabber ATX, Hikari LED Headlight Bulbs, Diode Dynamics SS3 Max Amber Fog lights, Tyger Rollup Bed Cover, OEM Bed Mat, Havoc OffRoad HS2 steps
    Dropping mine of this afternoon at the dealer. Hopefully will have some before and after pictures to post tomorrow.
  19. Apr 5, 2021 at 9:17 AM
    #799
    Lorescar
    Lorescar Well-Known Member
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    TRD Bilstein Lift & 265/75/16 Wildpeaks
    Has anyone installed this on one of the lower clip settngs? I'm not trying to get the full 2 inches up front. Closer to 1 inch.
  20. Apr 5, 2021 at 3:10 PM
    #800
    Bugeater
    Bugeater Member
    2018 Cement Grey TRD sport
    Has anyone made a DIY video on installing this lift yet?
