Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Sep 7, 2021 at 5:10 PM
    #1741
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    It took them literally all day to do mine. I dropped it off at 9am and didnt get it back until 5pm.
  2. Sep 7, 2021 at 5:26 PM
    #1742
    kddouglas
    kddouglas Well-Known Member
    Georgetown, TX
    2020 TRD OR 4x4
    4Runner SEMA wheels. TRD Factory lift kit.
    It took them two days to do mine. Doesn’t mean you should pay for more than what the book calls for installation (4-5 hours). Anything more than that I would question.
    I was charged for five hours.
  3. Sep 7, 2021 at 5:38 PM
    #1743
    Integerdy
    Eric
    So-Lame, Oregon
    They quoted me 2400$ before we began and that's what I paid.
  4. Sep 7, 2021 at 5:44 PM
    #1744
    kddouglas
    Georgetown, TX
    2020 TRD OR 4x4
    Sounds fair. Mine was $2100 which equated to 5 hours of labor after you subtract out the parts.
  5. Sep 7, 2021 at 6:16 PM
    #1745
    Forest Moon
    Forest Moon Well-Known Member
    Greater Lowell Area
    '24 OR 6mt Supersonic Red
    Eric2009Taco likes this.
  6. Sep 7, 2021 at 7:23 PM
    #1746
    Eric2009Taco
    Eric2009Taco Well-Known Member
    eric
    stock 2009 base Tacoma 4X4
    ARE camper shell, black wheels, and BF Goodrich tires
    I say buy it, that Army Green Tacoma deserves it!!!
  7. Sep 12, 2021 at 7:22 PM
    #1747
    Tacovandamme
    Tacovandamme New Member
    2020 MGM Tacoma TRD Off road
    What leaf pack did you end up installing in order to remove the rear 1" block and to maintain the height? I am looking for some help. I have the factory lift as well on my 2020 TRD offroad. I currently have the 1" rear spacer installed on my truck. My issue is that I have added 600 lbs to the bed and now the rear is now sagging about 1.5". I was thinking of getting the Deaver Stage 3 leaf pack but you are saying that it won't work with rear TRD Bilstein shock? I want to remove the block and put a new leaf pack on but don't know what will work for my application. Any help would be greatly appreciated?
  8. Sep 12, 2021 at 7:31 PM
    #1748
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I used the OEM leaf pack but installed a Torch 1.5" -2" AAL from Amazon in it (See link below). I had installed the Sumo Springs previously, so those will deal with extra heavy loads.
    Last time I measured the distance between the top of the Sumo Spring and the bump stops, it was a little over 2 inches. It may have settled to two inches now since I've installed and been using the truck with the AAL's.
    https://www.amazon.com/dp/B08VTVGCY...&pd_rd_r=230349ae-3db9-484b-a80d-c18edb2a6fb9
    deusxanime likes this.
  9. Sep 13, 2021 at 3:28 PM
    #1749
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    Quick update on my install (did the 2” up front and icon AAL for 1.5” in the rear)
    After about 500 miles I got rhythmic vibrations I could feel in the floor and through the gas pedal.
    I installed the ECGS bushing and now it’s smooth as butter again. If I could do it over, I would have done the bushing from the beginning… but, that’s life!
    Oatwillie and VaToy like this.
  10. Sep 13, 2021 at 4:28 PM
    #1750
    Tacovandamme
    Thanks for the help guys. I am in contemplating between 2 options.
    Option 1 - I spoke to a technical guy at Deaver today and he recommended that I go with the stage 2 U402 deaver springs (400 - 600 lb rating). He said with my 600 lb load it should drop my truck a bit. So basically will remove 1" rear spacer and install 2" (above stock tacoma) leaf pack which will put me 1" above factory TRD lift height and then my weight will bring it down a bit. Only problem is he doesn't know exactly how much it will come down.
    Option 2 - There are local shops in my area that specialize in leaf spring upgrades and will do an AAL and remove the 1" block. They say they can get my rear to the level I need and it's at half the price.
    Contemplating between both options.
  11. Sep 13, 2021 at 5:46 PM
    #1751
    jmd384
    jmd384 Well-Known Member
    2017 Inferno TRD Off Road
    Did you get it? If so. How was the install?
  12. Sep 14, 2021 at 2:39 AM
    #1752
    Forest Moon
    Greater Lowell Area
    No I didn't. This is the second dealership that has decided to not even return my calls anymore, even after getting a quote with a breakdown of labor and parts. I'm not going to hassle them if they clearly don't want to do business with me.
    I'm just going to wait until my scheduled maintenance(different dealership) and ask about it then. Just hoping I still have the extra funds available.
  13. Sep 14, 2021 at 2:59 AM
    #1753
    willtill
    Maryland
    Or Option 3 - Install the stage 2 U402 Deaver springs and leave the 1" rear spacer in place. Truck looks better with rake.
  14. Sep 14, 2021 at 6:29 AM
    #1754
    jmd384
    That sucks man. I wondering how hard it would be to adjust the lane departure sensors if needed along with the micro sonar. Looked like an attractive parts kit price since I do want the grill that comes with it. The 2 dealers I called weren't really helpful. They did quote it, but they didn't do it properly. It was 2200 to 2500 . I believe that 2500 price didn't even include an alignment
  15. Sep 14, 2021 at 12:25 PM
    #1755
    Tacovandamme
    Can you tell me how much weight you put in the bed of your truck? Any sag with the Icon 1.5" AAL? I'm thinking of putting a Deaver F85 Mini pack AAL to help with my 600 lbs in the bed.
  16. Sep 14, 2021 at 2:14 PM
    #1756
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    Not much weight kept in my bed on a regular basis. MAYBE 50 pounds all the time. Obviously no sagging with that low of weight. If you keep weight back there on a regular basis you would want to keep the overload leaf in vs taking it out to still get the advertised 1.5” of lift. The icon instructions go through this.
    If you are keeping 600 pounds back there all the time then you need a full leaf pack. Don’t even think about an AAL helping out with that much weight!
    Good luck!
  17. Sep 20, 2021 at 5:54 PM
    #1757
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    How was the ecgs install? Did you buy all the tools and new axle seal?
  18. Sep 20, 2021 at 6:11 PM
    #1758
    SnuggleTruck
    Alex
    Fort Myers
    2020 DCLB TRD OR
    Easy to do. I did buy the install tools and a new seal.
    WhiteTaco20[QUOTED] likes this.
  19. Sep 20, 2021 at 6:48 PM
    #1759
    Eric2009Taco
    eric
    Is there a video posted for ecgs install? Thanks
  20. Sep 21, 2021 at 2:39 AM
    #1760
    WhiteTaco20
    Perkasie, PA
    There are videos on youtube.
    gsubioguy likes this.
