Toyota TRD OEM lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpensirG, Nov 22, 2020.
  1. Feb 12, 2021 at 1:38 PM
    #161
    ToynbyuTicotex
    ToynbyuTicotex Well-Known Member
    Central Virginia
    1999 Xtra cab V6
    I had my dealership box up all the new parts they took off the truck, I figured they are brand new, why not keep them? Now they are sitting in my garage taking up space. Anyone else keep them? if so, what do you plan on doing with them?
  2. Feb 12, 2021 at 1:47 PM
    #162
    Brushog65
    Brushog65 Well-Known Member
    2021 Trd off road
    I kept mine too. Just because there new, hated to just throw them out.
  3. Feb 12, 2021 at 1:51 PM
    #163
    danoo
    danoo Well-Known Member
    2021 Trail Edition
    Would love to know what package the garnish comes in...looking to see if this is a cheaper way to get an oem pro grille and garnish
    Onefastseven likes this.
  4. Feb 12, 2021 at 2:04 PM
    #164
    ToynbyuTicotex
    Central Virginia
    1999 Xtra cab V6
    Do you have any idea what you are going to do with your parts?
  5. Feb 12, 2021 at 2:08 PM
    #165
    Brushog65
    2021 Trd off road
    I have no idea. Just hated to throw them out. Might run into somebody needing them one day.
  6. Feb 12, 2021 at 2:08 PM
    #166
    danoo
    2021 Trail Edition
    AMSK.505, rubiconjp and eclane like this.
  7. Feb 12, 2021 at 2:51 PM
    #167
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    What springs do you use
  8. Feb 12, 2021 at 3:07 PM
    #168
    TacoMan408
    TacoMan408 Well-Known Member
    CA
    2016 TRD Sport Manual
    OVTune (04B13+1.05 87 FOB), Morimoto XB Headlights, Toyota LED Fog Lights, Toyota TRD Lift Struts, Wheelers Progressive AAL, TRD Pro Tail Lights, 17" TRD Pro SEMA wheels, BFG 285/70R17, TRD Skid Plate, Bakflip MX4, OEM Audio +, Anytime Front Camera, G-Tek Fab Door Sill Protectors, WeatherTech Floormats Suntek Carbon 35% Tint
    I’m planning on using my stock OEM springs and a 3 leaf AAL for the rear. And since this part number didn’t come with new bushings, I think I’m going to pick up some new ones as well
  9. Feb 12, 2021 at 3:11 PM
    #169
    mysubiewasalemon
    I saw one with this lift at the dealer with red springs that’s why I asked
  10. Feb 12, 2021 at 3:34 PM
    #170
    TacoMan408
    CA
    Here is the Accessory Installation Practices document for the entire kit PT84K-35220 if anyone is interested.
  11. Feb 12, 2021 at 4:02 PM
    #171
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    From the install guide that just got posted:
    When the TRD Lift Kit installed, the OE fog lights will no longer comply with most US State lighting regulations for fog light height position. The OE fog lights must be disabled & removed in order to comply with these US States’ lighting regulations for on-road usage (at the time of writing these instructions): AL, AR, AZ, CO, CT, DC, FL, GA, ID, IN, KS, LA, MD, ME, MI, MN. MT, ND, NM, NV, OH, OR, SC, TX, WA, WV
    ScootARoot and creynol6[QUOTED] like this.
  12. Feb 12, 2021 at 4:23 PM
    #172
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    That argues against having a dealer do the install if you want to keep your dogs.
  13. Feb 12, 2021 at 4:28 PM
    #173
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    F that. Happy with my 5100s and my fogs!
    Burns likes this.
  14. Feb 12, 2021 at 4:55 PM
    #174
    Tacobelt
    Tacobelt Well-Known Member
    2016 TRD Sport AC 6MT
    Those look great!
  15. Feb 12, 2021 at 5:07 PM
    #175
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    It's not that big of a deal, just the connector at the fog, the fuse, and the cover - the fog light stays installed. Just pull the cover at home, reconnect, and seat the fuse.
  16. Feb 14, 2021 at 6:10 AM
    #176
    Iyabyas
    Iyabyas Active Member
    Paul
    DCSB TRD OR 4x4
    None
    What Brand tire is that? Looks good. Thanks
  17. Feb 14, 2021 at 8:40 AM
    #177
    creynol6
    creynol6 Active Member
    2021 TRD Off Road
    Goodyear Wranglers that came w the truck when I bought it. Not sure if Toyota still does region-specific options, here in the south east the tires came w the "XP Predator" package. Rims/blackout trim pieces/tires/etc..
    Iyabyas[QUOTED] likes this.
  18. Feb 14, 2021 at 9:03 AM
    #178
    Iyabyas
    Paul
    DCSB TRD OR 4x4
    None
    Im going to be doing the same
    TRD lift kit, deciding if I should stay with 265/70 or 265/75. To me, your truck looks good with stock size tires. I think if I get an aggressive looking tire and stay 265/70 it’ll give the appearance of a little bit big tire?. I’m trying to get away with smallest tire ( but still looks good) to save a little on mpg.
    BrokeKayaker and VaToy like this.
  19. Feb 14, 2021 at 9:09 AM
    #179
    creynol6
    2021 TRD Off Road
    I think the little extra sidewall w the 75's would look great w the lift.
  20. Feb 14, 2021 at 11:32 AM
    #180
    TCTacoma12
    TCTacoma12 New Member
    Any one know why this will not fit a 2WD? I am only looking to buy the shocks with no block and I already have a pro style grill. Has anyone just installed the 4 shocks?
