Toyota Tundra Techstream Clone for 35-45 bucks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ggms16, Aug 6, 2012.
  1. Aug 7, 2012 at 2:59 PM
    tango down
    tango down Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    im getting one
  2. Aug 7, 2012 at 6:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    This is the main reason I'm buying it.
    So does it read and display any TPMS units in range and allow you to register them, or is a separate "box" still needed to wake the sensors and read their serial numbers?
    Can this be used to "update" my '08 to read only the 4 sensors instead of 5?
  3. Aug 7, 2012 at 6:21 PM
    ggms16
    ggms16 [OP] Well-Known Member
    1st. You'll need to unmount the tires, and type down your sensors serial number.
    2nd. No, you will not be able to make it read only 4, you'll have to program all 5 sensors.
  4. Aug 7, 2012 at 6:21 PM
    ggms16
    If you never replaced any sensor but the light is still on, you can reset the sensors using the techstream.
  5. Aug 7, 2012 at 6:31 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ahh...
    My light is flashing for a while then goes solid. I've never swapped the sensors, but I bought the truck used from a non-Toyota dealer, and I suspect that the spare is not the original (hub fits SUPER tight). I'm thinking that a 1st Gen spare got slapped under there with a random sensor, but really no way of knowing.
    2008, could just be dead sensors/batteries.
  6. Aug 7, 2012 at 6:37 PM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Does it allow you to log the sensors for playback?
  7. Aug 7, 2012 at 6:48 PM
    ggms16
    I would first try to reset them with techstream.
    If you need help with that PM me and I can try to guide you by phone.
  8. Aug 7, 2012 at 6:48 PM
    ggms16
    What do you mean exactly?
  9. Aug 7, 2012 at 6:53 PM
    MadToy
    Nick
    Huntersville, NC
    Could I log the short term and long term fuel adaptives?
    Disclaimer: Not sure if that's what the PID's are called for Toyota.
  10. Aug 7, 2012 at 8:25 PM
    ggms16
    Yes. you can
  11. Aug 8, 2012 at 3:52 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    The techstream menu interface I had for the tundra had 5 spots for sensors codes.
    This was in line with the FSM posted online with NCTTORA.
    I had my 4 original sensor codes off my factory steel wheels.
    When I bought my RW wheels & tires, the tpms were already installed.
    The tire shop read the codes w/ their handheld scanner tool without breaking them down.
    I asked them to give me the codes as well.
    Now it is plug in obdc attached to laptop, fire up software, make changes.
    There were guys at TT that reported different menus between model years in the tundras & also some of those who tried it on 1GEN vs 2GEN tacomas.
    Anyone in VT who want to try it on their tacoma I would gladly meet them & let them see how they like it. At tundratalk they started a thread like that offering locality use.
    My tire shop was able to read my codes without breaking down the tire. They could give you the four you have, then,
    if techstream works the same for the tacoma as it did in my tundra, eliminate the code that is no longer present
  12. Aug 8, 2012 at 5:13 AM
    MadToy
    Nick
    Huntersville, NC
    Perfect! Just bought it :)
  13. Aug 8, 2012 at 5:20 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Usually means you have a sensor going bad.
  14. Aug 8, 2012 at 2:14 PM
    ggms16
    Or just the battery. Easy fix
  15. Aug 8, 2012 at 5:53 PM
    #35
    Rich91710
    Rich
    Los Angeles
    08 Base
    Easy fix if you own a tire machine or have the desire to pay a shop to break it down, then remount after you take it home and replace the battery.
    If it's a bad sensor, I'm just going to disable the system until I get new rims.
  16. Aug 8, 2012 at 6:09 PM
    #36
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Can you turn off the TPMS (disable) or at least put the same code on all 5 wheels. I changed my wheels, no TPMS in them. Thought on maybe just mounting one sensor in the spare tire and register all 5 with the same sensor number.
  17. Aug 9, 2012 at 7:03 AM
    #37
    ggms16
    I'm not sure if you can set the same code for all 5 wheels. But it sounds 'doable'
    No, there's no way to disable this. Remember now its required to have tpms on new cars.
  18. Aug 10, 2012 at 1:50 PM
    #38
    MadToy
    Nick
    Huntersville, NC
    Ok - got mine, but very confused trying to install the software. The instructions don't make much sense on how to register it? Any help would be very appreciated :)
  19. Aug 10, 2012 at 5:28 PM
    #39
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Before you run the software copy the " getpeculiarid.dll " file from the Easyway ... folder into the C:\Program Files\Toyota Diagnostics\Techstream\bin folder over writing the original file. Then start the software and use one of the included keys listed in the text file to register.
    US = 559627f5974491d41267c83cf039432130001204210659
    EU = 252ddc8d7885eeaf40f4198dfae785fa30001204210659
    JP = d9eec4cf9a04f0604b169ced5044355b30001204210659
    OTHER = 19dd8e33717087bd7c181e6824c7595130001204210659
  20. Aug 10, 2012 at 6:34 PM
    #40
    MadToy
    Nick
    Huntersville, NC
    Edit!! Ah - I found it on the disk. Thanks!!!!!
