Toyota Tundra Techstream Clone for 35-45 bucks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ggms16, Aug 6, 2012.
  1. Sep 15, 2012 at 10:21 AM
    #61
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
  2. Sep 15, 2012 at 2:28 PM
    #62
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Double check that... the CD is only a 3"
  3. Sep 25, 2012 at 6:53 AM
    #63
    BaLLZaCH
    BaLLZaCH Active Member
    Good morning everyone,
    Customize function does not work on my 2012... Everything else seems to monitor fine (once started and idle for a few minutes), but customize does nothing :(
    I get 3 options. Warning, Unit Convertion, Display.
    When I click them or use the 'customize' button, the computer/software 'thinks' for a minute, it shows a pop-up of a progress thinker-bar, then it goes back to the previous screen. No additional popups and no settings.
    I have tried 2 computers, 2 versions of software, xp mode, win7, truck on - off - acc - and running, and get the same results.
    I even selected '2011' just to see.... Same thing...
    It should be noted that the software has NOT been registered.
    At least I have an pin-point accurate tire pressure gauge now... :rolleyes: :(
    Any ideas ?
    Thanks!
    [EDIT, I cut the sh(i)t in half and gave up... ] .. Ohhh and yes, it 'can' disable seatbelt chimes on 2012 ...
  4. Sep 25, 2012 at 9:15 AM
    #64
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    Ballzach - I have a 2012 also.. that sucks.. what verison of the Techstream are you running I found 7.12.000 that I was going to use instead of the older 7.11 version that ships. I'll give it a try this weekend if the software works.
    did you follow the readme.txt for the install, where you backup a dll and then use the keys to register the software? I believe you have to this before running the software the first time also.
  5. Sep 25, 2012 at 10:30 AM
    #65
    BaLLZaCH
  6. Sep 25, 2012 at 3:59 PM
    #66
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It works on my 2012 just fine. I think you have a registration issue. It will let you look but not touch.
    Before you run the software copy the " getpeculiarid.dll " file from the Easyway ... folder into the C:\Program Files\Toyota Diagnostics\Techstream\bin folder over writing the original file.
    Then start the software and use one of the included keys listed in the text file to register.
    US = 559627f5974491d41267c83cf039432130001204210659
    EU = 252ddc8d7885eeaf40f4198dfae785fa30001204210659
    JP = d9eec4cf9a04f0604b169ced5044355b30001204210659
    OTHER = 19dd8e33717087bd7c181e6824c7595130001204210659
  7. Sep 25, 2012 at 5:10 PM
    #67
    BaLLZaCH
  8. Sep 25, 2012 at 11:39 PM
    #68
    Jimmyh
    SC
    2012 Prerunner SR5
    Ballzach
    You got a PM.
    or
    PM me your email address where you can receive a 92MB attachment... :)
  9. Sep 26, 2012 at 7:23 AM
    #69
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    PM sent ;)
  10. Sep 28, 2012 at 7:16 AM
    #70
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    Does anyone know if the speedo can be corrected for tire size with this software?
  11. Oct 14, 2012 at 5:33 PM
    #71
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    that small disk just stuck in my cd drive
  12. Oct 14, 2012 at 6:19 PM
    #72
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Yes, you can. But when you switch wheels (summers to winters for example) you have to manually switch from main to 2nd, either with this techstream clone or other scan tool. It saves entering all the ID numbers though.
  13. Nov 2, 2012 at 6:13 PM
    #73
    JoeyBones
    JoeyBones Member
    Joe
    Tampa/Sarasota, FL
    '19 Access Cab 4X2 SR
    Just ordered one (from the China site - the US site gave me a 404 error). Anxious to play around with this thing..
  14. Nov 2, 2012 at 7:33 PM
    #74
    paid4c4
    paid4c4 Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    #74
  15. Nov 2, 2012 at 8:32 PM
    #75
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    #75
  16. Nov 2, 2012 at 11:16 PM
    #76
    mh3kgt
    mh3kgt -TACOMBO-
    Elko, NV
    07 TRD Sport
    OME 885's, OME Nitros front, Billy 5100's rear, 1.5"AAL, Satoshi'd Billet Grille, 18" Moto Metal 955's Plastidipped, more to come
    Anyone know for sure if this will program new keys on an 07 Tacoma? I have a spare that the dealer says they couldn't get to program, but i think they just want me to buy a spare from them since mine wasn't bought from them.
  17. Dec 4, 2012 at 8:59 PM
    #77
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Interesting results for me. I was finally able to get version 7.10.030 working after downloading from the skydrive link.
    The only thing I was able to do on my '12 however, was disable the seatbelt warning chime and zero-set the passenger detection system. Interestingly enough, it also told me that my tpms system was turned off. The sensors are registered and it looked like I could register other sensors, but if there was a way for me to turn it back on or change anything else about it (second set of sensors) I couldn't figure it out.
    I had a lot more things I could change on our '08 Sienna (remote double click unlock, time delay for interior lights, auto lock and unlock via transmission, etc.) but one thing I couldn't do was disable the seatbelt warning. I think there's a procedure similar to the <'12 tacomas for that though.
    If nothing else, it's a seatbelt warning disabler and cheap obdII reader.
  18. Feb 12, 2013 at 12:05 AM
    #78
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
  19. Feb 12, 2013 at 7:14 PM
    #79
    Rich91710
    Rich
    Los Angeles
    08 Base
    No...
    My suspicion is that Toyota shut the US site down since they were selling hacked software.
    Possibly too many people trying to connect to TIS alerted them to the "warez" being out there.
  20. Feb 13, 2013 at 9:12 AM
    #80
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    guess ill have to order from china source
