Toyota Warranty
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacaco81, Mar 1, 2017.
  1. Mar 1, 2017 at 6:57 PM
    tacaco81
    tacaco81 [OP] Member
    2016 Grey Tacoma TRD Off-Road
    So does anyone know if Toyota warranty will cover Tacomas that have been leveled. Just a leveling kit and 33 inch tires? If anyone knows or has been through warranty issues with a lifted/leveled truck please let me know what you have experienced.
  2. Mar 1, 2017 at 6:59 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Suspension related problems won't be covered. Anything else (radio, engine, etc.,) will be covered unless they can prove that suspension caused whatever problem you're claiming.
    shakerhood likes this.
  3. Mar 1, 2017 at 7:03 PM
    tacaco81
    I took to the dealer today after noticing a small amount of fluid under the truck where it was parked. They said that the power steering pump is bad and that they wont cover it under warranty. Its a 2016 TRD Off Road with 13k miles on it. So I dont know what the deal is?
  4. Mar 1, 2017 at 7:07 PM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    They should cover it. Call corporate Toyota or go to a different dealer.
    GPsevinSixx and c4lvinnn like this.
  5. Mar 1, 2017 at 7:08 PM
    tacaco81
    Ok, I have a different dealer that I will try. I just didnt know what was covered and what wasnt.
  6. Mar 1, 2017 at 7:16 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    They have to prove that the Modifications you made were the cause of what has failed.
  7. Mar 1, 2017 at 7:28 PM
    tacaco81
    Who would be the one to prove that? The dealer I went to said that Toyota would come look at it if I requested them to but he said that he knows that they wont cover it. Said the bigger tires caused it....
    I have had lifted trucks my entire life and never had a problem. Ive had over 40 inch tires and they never affected the power steering pump!
  8. Mar 1, 2017 at 7:35 PM
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    Based on my experience so far with Toyota about my clutch, I don't have any faith in them!
  9. Mar 1, 2017 at 7:41 PM
    marazaii
    marazaii Well-Known Member
    Mario
    Helena
    '16 DCSBOR4X4
    The way they look at it is, it takes an extra effort for the pump to handle heavier wheels.
  10. Mar 1, 2017 at 7:48 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    What size lift? You have smaller tires you can put on temporarily?
  11. Mar 1, 2017 at 7:49 PM
    tacaco81
    It is just a leveling block in the front. I dont believe anything in the back. I bought it used like this. There is a spacer on top of the front shocks. No I dont have smaller tires
  12. Mar 1, 2017 at 7:51 PM
    20tacoma17
    2017 DCLB Sport AT
    OK, was just a thought before you took it to other dealer? Did it come with 33's
  13. Mar 1, 2017 at 7:54 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    The lift shouldn't prevent the dealership from telling you that whatever problem you have is "normal." Unless of course the problem is a direct result of the lift. Find another dealer.
  14. Mar 1, 2017 at 7:56 PM
    tacaco81
    Yes. I bought it used tho. Looking at the tire specs theres like a 5-7 pound difference
  15. Mar 1, 2017 at 7:59 PM
    20tacoma17
    2017 DCLB Sport AT
    If you bought it used just like that and a 2016 it should have the warranty. Unless is states in your contract that they will not cover items because of larger tires as sold to you, it should be covered. I bought my 2017 new lifted with larger tires. Not 33'sure but still larger. I made sure I had full coverage on everything with those items.
  16. Mar 1, 2017 at 8:02 PM
    tacaco81
    I have contacted the dealer that I bought it from as they are 3 hours away. They stated that it should be covered. So Im waiting to hear back from them as to what the next step I should take is.
    GPsevinSixx and shakerhood like this.
  17. Mar 1, 2017 at 8:04 PM
    tacaco81
    I do apologize... they are not 33 they are 31 inch tires
  18. Mar 1, 2017 at 8:05 PM
    20tacoma17
    2017 DCLB Sport AT
    Good, hopefully they can work something out with the dealer closer to you. Good luck
  19. Mar 1, 2017 at 8:05 PM
    tacaco81
    Thanks for the response and the help.
  20. Mar 1, 2017 at 8:08 PM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    31s are the stock size for six lug trucks. I'm utterly confused.
