Toyota Warranty
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Deltawaterfowl22, Sep 29, 2022.
  1. Sep 29, 2022 at 12:32 PM
    adamceckhardt
    adamceckhardt Well-Known Member
    I was being facetious. Magnuson is not going to pay for it. They have a 3 year warranty on the supercharger itself, with many caveats, and specifically say that they don't warranty anything to which it's attached.
    cammerv8 likes this.
  2. Sep 29, 2022 at 12:33 PM
    Deltawaterfowl22
    Deltawaterfowl22 [OP] Well-Known Member
    Cole
    2018 Tan Toyota Tacoma
    5.29 gears in rear, Magnuson supercharger Tow package, Winch, Lights out the wazoo
    Yeppp pretty sure they do especially on Tundras
    Benny blanco[QUOTED] likes this.
  3. Sep 29, 2022 at 12:34 PM
    Deltawaterfowl22
    Cole
    Ah sarcasm strikes again. Yes I did read they only cover certain things. Which makes you wonder they only cover things that it can directly effect?
  4. Sep 29, 2022 at 12:34 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Read this. https://www.tacomaworld.com/threads/ffs-lets-all-stop-referencing-the-magnussen-moss-act.609911/
    The dealer can deny warranty for anything. It is then up to the consumer to prove the issue did not. The link above will tell you the cost and time involved to prove it. Good luck.
    Plain Jane Taco likes this.
  5. Sep 29, 2022 at 12:36 PM
    Deltawaterfowl22
    Cole
  6. Sep 29, 2022 at 12:36 PM
    adamceckhardt
  7. Sep 29, 2022 at 12:36 PM
    yuber814
    yuber814 Member
    arnold
    2020 Quicksand Sport
    hi op. Just had my regear done last november. i have a 2020 3rd gen regeared to 5.29. finished the gear break in change fluids and stuff. december came and i was going on a long trip( from california to alberta). my transmission didnt work, it wouldnt shift after 2nd gear. it broke down in salt lake city. mark miller toyota didnt deny my claim for a new transmission replacement. a month later i got my truck back.hope this help you
  8. Sep 29, 2022 at 12:37 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    The only way I can think of to get around the super charger being blamed is to ask if the super charger puts more than 6000lb of strain on the transmission. Because that is what the trucks transmission is designed to be able to pull.
    It would be a long shot and hard to compare, but its a straw to grasp at.
  9. Sep 29, 2022 at 12:38 PM
    Deltawaterfowl22
    Cole
    They have the equipment to tell them if there was any fluctuations in rpms prior to it slipping. I was told it smelled burnt up. But Im going to take another guys advice and research other stock toyotas with transmission issues w/o sc
  10. Sep 29, 2022 at 12:39 PM
    Deltawaterfowl22
    Cole
    Yes it does help somewhat maybe I need to contact them for guidance on the issue thank you sir
  11. Sep 29, 2022 at 12:39 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Yep, this! Dealer does not have to prove Jack shit! They approve or deny warranty claims, that's it! They will certainly tell you why they are denying your warranty claim, but they don't have to prove anything. It you choose to fight it, you then have the burden to prove that your aftermarket supercharger was not the cause.
    Best of luck and carry on!
    cammerv8 and Chew like this.
  12. Sep 29, 2022 at 12:39 PM
    yuber814
    yuber814 Member
    arnold
    Mine isn't a supercharger but i did an aftermarket gear and they still covered my repair under warranty
    Deltawaterfowl22[OP] likes this.
  13. Sep 29, 2022 at 12:43 PM
    5nahalf
    Erik
    Minnesota
    Also I just want to note, I had a leak in the drivers side floor pan. Toyota blamed the power wire for my amp that went through the passenger side firewall. Somehow they determined that water was traveling along the wire, through the sealed hole, up over the transmission tunnel and then pooling on the driverside... all while not leaving a drop on the passenger side where the wire comes into the truck.
    Benny blanco likes this.
  14. Sep 29, 2022 at 12:44 PM
    Deltawaterfowl22
    Cole
    Wow im sorry to hear that
  15. Sep 29, 2022 at 12:51 PM
    #35
    Sungod
    Sungod Well-Known Member
    St Augustine
    So your assertation is that even though you cranked up the HP and torque, that has nothing to do with your trans failure? :facepalm::facepalm::facepalm:
    stu8319, cammerv8, ToyoTaco25 and 4 others like this.
  16. Sep 29, 2022 at 1:04 PM
    #36
    Deltawaterfowl22
    Cole
    Never had my truck hitting 6K rpms
    even when it started to slip I would let off the pedal if it got to 4500 rpms
    CalcityRenegade likes this.
  17. Sep 29, 2022 at 1:05 PM
    #37
    Deltawaterfowl22
    Cole
    Auto Transmission can handle a supercharger its not like Im on fast and loud ripping down the road with it.
  18. Sep 29, 2022 at 1:14 PM
    #38
    Sungod
    St Augustine
    Haaaa, you are hilarious. You really think you can crank up 32% more power and not have an issue? Seriously? You have to be joking. Your warranty is to cover defects, not modification failures. Adding that much more power and having a problem is by no means a defect. You have to be a man about this and accept responsibility for your actions. I know it is hard to accept, but that is the reality. Do the right thing and go out and find a transmission that can handle the extra power. That is the price you pay for modifications. The more you spend, the more you break.
  19. Sep 29, 2022 at 1:41 PM
    #39
    adamceckhardt
    Toyota isn't buying you a new transmission, Bubba.
    cammerv8, ToyoTaco25, Chew and 2 others like this.
  20. Sep 29, 2022 at 1:48 PM
    #40
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    This is it
    Primo 95[QUOTED] likes this.
