Toyota won't perform a recall because my vehicle is modified
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ellswj86, Apr 22, 2019.
  1. Apr 22, 2019 at 5:56 PM
    Puck
    Puck Well-Known Member
    South Florida
    Black SR5 DCSB
    I’m curious when a dealership performs warranty or recall services are they not reimbursed by Toyota Corp for the labor and equipment. If this is the case that would be more money flowing through that Toyota dealership hopefully meaning more money.
    TLDR: What’s the benefit for a dealership to deny recall work
  2. Apr 22, 2019 at 6:00 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    just like some dealers will turn off the seat belt chime and some will not. guess you should try other dealers.?
  3. Apr 22, 2019 at 6:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No. The dealer nor Toyota have to prove anything. They can deny warranty and tell you their reason. It stops there unless YOU think they are wrong and then you take them to court. You pay for your lawyers and expert witnesses and they bring in their army of experts and lawyers. Good luck with that.
    MM Act was written to make manufacturers act in good faith, meaning they cant deny a transmission warranty because you changed your head unit.
  4. Apr 22, 2019 at 6:09 PM
    Ellswj86
    Ellswj86 [OP] Well-Known Member
    Jarrad
    2017 TRD DCSB
    I had a 2017 until a 16 year old girl, texting and driving crossed the center line
    whatstcp likes this.
  5. Apr 22, 2019 at 6:11 PM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Glad you walked away from that!
  6. Apr 22, 2019 at 6:13 PM
    mhowe441
    mhowe441 Well-Known Member
    PA
    19 Quicksand TRD OR 4DSB
    That's Freedom Toyota for ya...
    Stocklocker[QUOTED] likes this.
  7. Apr 22, 2019 at 6:24 PM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Finally someone who actually understands the Magnuson Moss Act.
  8. Apr 22, 2019 at 6:29 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Yeah, but altering the height of the grille radar sensor by lifting a vehicle, or changing the grille, does change the radar, even if the change is not substantial.
    Toyota is not denying the warranty, they are just insisting that it be done with the sensor is it’s original location and height. Other locations and heights may not match with the calibrations they are looking for.
  9. Apr 22, 2019 at 6:32 PM
    JNG
    I think we are agreeing with each other.
    hiPSI and Stocklocker[QUOTED] like this.
  10. Apr 22, 2019 at 6:37 PM
    Stocklocker
    17TRDORDCSBAT
    Ok....my bad.....I’m having a contradictory day it seems.
    gurneyeagle and hiPSI like this.
  11. Apr 22, 2019 at 6:43 PM
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    Wouldn't a Tacoma having a pro grill and a lift kinda even things out ? Truck lifted and a lower mount of the sensor on a pro grill should measure close to a stock non pro correct ?
    71tattooguy, cowsquatch67 and TimC like this.
  12. Apr 22, 2019 at 6:47 PM
    JNG
    Pro is only higher than an OR (and I assume Limited, SR5, SR, Sport) by an advertised 1". Some folks who have measured both say it's closer to 1/2 or maybe 3/4". Some folks are lifting their trucks a couple of inches to several inches. I know it's splitting hairs but the Pro isn't 4" taller than an OR or anything like that. So with so many variables I don't think it works out.
  13. Apr 22, 2019 at 6:48 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    I work for a ford dealer and if ford is paying for something, recall/warrenty/whatever we have to be careful when dealing with warrenty/recalls on modified vehicles cause if Ford Corp says that we should not have done X Y Z they will charge us back the labor and parts time 10. So if it pays an hour @$130/hr and parts are $500 then they could kick us a bill for $6300.
    Yeah warrenty/recall pay is shit, guy next to me found the OEM pads were what was making noise and he only got paid 0.1 hours to determine it was the brake pads and then remove and replace said front brake pads, no diag pay, only paid for 6 minutes of his life.
    Bleep100, AxisCab and Boghog1[QUOTED] like this.
  14. Apr 22, 2019 at 6:51 PM
    TSAVO
    TSAVO Well-Known Member
    Tempe, AZ
    2018 TRD OR
    So since I actually had mine recalibrated after the lift I wonder if I’m going to get any flak for it since it is properly calibrated for its current ride height.
  15. Apr 22, 2019 at 6:51 PM
    #35
    Scarekrow75
    Scarekrow75 New Member
    2018 Cement Gray TRD Sport Double Cab
    Bilstein 5100s 3rd clip, dif drop KO2s 265 70 r18
    Went to the dealer for my 1 year service. go got the same run around. They set it up for the recall then denied it. I was like, you are the one that told me it had to be done. I don't get how changing out the grill stops them from putting a strip of 3m tape on a sensor. My bigger concern is up the road when it does leak due to them denying my recall then they deny fixing the issue due to the grill change.
    cowsquatch67 likes this.
  16. Apr 22, 2019 at 6:52 PM
    #36
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It truly does not matter. Stock is what they warranty. We do the same thing. If it's in the as sold condition then we happily warranty it. If a customer makes a change? All bets are off.
    JNG and joeyv141 like this.
  17. Apr 22, 2019 at 6:53 PM
    #37
    joeyv141
    Virginia
    Yeah hopefully it evens out in the end, screw evens out, hopefully if works out in the techs favor in the long run.
    I love the Ford Fusion airbag recall since you have to remove the dash it pays 2.8 hours and I can do it in about 1.5 now, but other recall for F150 only pays max of 0.4 when Ive found its just easier to pull the whole damn front seats out and work on them instead of doing it in vehicle, I defiantly lose time on that.
  18. Apr 22, 2019 at 7:03 PM
    #38
    Comato$e
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    You're stating the obvious ….all i'm saying if its with in spec it SHOULD'NT be a problem. I got mine done and i'm lifted with a pro grill so all bets weren't off
    Taco_Craig and DavesTaco68 like this.
  19. Apr 22, 2019 at 7:15 PM
    #39
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    I believe they can’t deny a safety recall, if you have an accident and it was caused by a faulty tss, they can be held liable as well. No one signed any documentation were it says that you can’t modify your truck in which is also your property. At least I don’t remember signing any papers stating that..:notsure:
    Alnmike and Comato$e like this.
  20. Apr 22, 2019 at 7:16 PM
    #40
    Abelgonz
    Abelgonz Well-Known Member
    Abel
    Arizona
    2017 Barcelona Red Tacoma TRD OR
    Glad you were able to walk away from that.
