Toyota won't perform a recall because my vehicle is modified
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ellswj86, Apr 22, 2019.
  1. Apr 23, 2019 at 8:05 AM
    #81
    Roddy13
    Roddy13 Well-Known Member
    Its a safety feature, I don't blame them for not wanting to do the work. If the tsb alters the calibration and then those features stop working or have an issue they are left troubleshooting the problem.
    In reality they should do the TSB and have you sign a waver that if additional troubleshooting or repairs are needed on the system, as a result of your modifications impacting expected functionality that you would be on the hook for labour and parts to make the system work correctly.
    JNG likes this.
  2. Apr 23, 2019 at 8:51 AM
    #82
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    I ran my recall done last week.
    All I have done so far is 265/75/16 tires.
    Technically modified since I have larger tires.
    They never said a thing about them.
    Done at South Bay Toyota in Gardena, CA
    Maffee88, 02Duck and GreyBaldTaco like this.
  3. Apr 23, 2019 at 9:02 AM
    #83
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    Its been tested and certified as a stock truck under different conditions, including a loaded bed. It hasnt been tested with random suspension. If anything you're adding another reason they can argue out of it. Maybe your lifted suspension has a softer rear than stock and angles nose up more than stock with the same load, on top of the front being 2 inches up. Or maybe not. The point is they havent tested it and arent gonna calibrate it and assume liability on a radar set up they havent tested.
    Boghog1 and JNG like this.
  4. Apr 23, 2019 at 9:31 AM
    #84
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    But not the 2016, because they don't have electric sliding rear glass. :boink:
    Jaque8 and Stocklocker[QUOTED] like this.
  5. Apr 23, 2019 at 10:01 AM
    #85
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    What the hell does this TSB have to do with what angle your truck is at? The TSB is to fix water intrusion is it not? Issues with TSS going off incorrectly are a symptom of water intrusion as per the TSB.
    If the TSB was for sensors going off relative to their current alignment then I could see how having a lifted vehicle would be grounds for refusal; but not to fix a damn leak.
  6. Apr 23, 2019 at 10:32 AM
    #86
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dude, Toyota writes the rules, not you. When you bought the truck you agreed to this.
    Now, you have posted this comparison twice. Let me explain:
    At stock height with a fully loaded bed, the TSS will work and Toyota will back that up. Let's call this "X angle."
    If you lift it two inches, and then fully load the bed, the angle will be "X" + 2 angle. Toyota will not be responsible because they didn't test this. Get it?
    Jaque8, JNG and Boghog1 like this.
  7. Apr 23, 2019 at 10:47 AM
    #87
    bmorgan1022
    bmorgan1022 Well-Known Member
    Atlanta, GA
    2018 Tacoma SR5
    what are they doing with dealer lifted trucks?
  8. Apr 23, 2019 at 10:48 AM
    #88
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    So X angle is with a loaded bed. Then Y angle is without a loaded bed. The sensor works both at angle X (Which would be variable itself due to different weights the bed could hold) and Y angle. The sensor is capable of working at multiple different angles. That's the point I'm getting at. What we don't know is what is the range the sensor works within? And are certain modified trucks operating outside of the range?
    Alnmike, DavesTaco68 and Dryfly24 like this.
  9. Apr 23, 2019 at 11:09 AM
    #89
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    How can you not understand that it does not matter. Toyota makes the rules and your logic does not apply.
  10. Apr 23, 2019 at 11:10 AM
    #90
    GreyBaldTaco
    2019 F150 5.0
    Why are you so upset about this?
  11. Apr 23, 2019 at 11:10 AM
    #91
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Of course they are, and if they are in an accident and try to blame Toyota they will laugh.
  12. Apr 23, 2019 at 11:11 AM
    #92
    GreyBaldTaco
    2019 F150 5.0
    Can you show me the data on that?
  13. Apr 23, 2019 at 11:16 AM
    #93
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
  14. Apr 23, 2019 at 11:22 AM
    #94
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    What you fail to understand is that all his points are valid and if it comes down to it I bet Toyota loses in a lawsuit.
    Alnmike and GreyBaldTaco like this.
  15. Apr 23, 2019 at 11:30 AM
    #95
    GreyBaldTaco
    2019 F150 5.0
    Those look delicious
  16. Apr 23, 2019 at 12:14 PM
    #96
    trajiiic
    trajiiic Well-Known Member
    Marines.... Stay away from my ACOG.
    Boghog1 likes this.
  17. Apr 23, 2019 at 12:16 PM
    #97
    trajiiic
    I JUST did the OEM TRD Pro grill swap and my VIN is on the TSB list. I'll just take 30 min out of my day and swap the grill back for a day or 2 to get the TSB done.
  18. Apr 23, 2019 at 12:22 PM
    #98
    GreyBaldTaco
    2019 F150 5.0
    I have an OEM TRD Sport/OR grill on my SR5 and 265/75r16's. The sensor is technically in the same spot, and its an OEM grill. I am curious to see what they have to say when I bring it in for my 15k service.
    cowsquatch67 likes this.
  19. Apr 23, 2019 at 12:23 PM
    #99
    TacoOR
    TacoOR Member
    Jeff
    Georgia
    2018 TRD OR 4x4 DCSB MGM
    Just got back from the dealer for the recall. 2018 OR DCSB. I have a pro grill installed with T4R Pro rims and 265/70/17 KO2’s, stock suspension. They performed the fix with no issues. My work order says that they inspected the millimeter radar sensor, no replacement needed, reprogrammed the ECU and performed repair B. Repair B is a piece of foam wrapped around the upper passenger side screw post on the sensor. If you weren’t looking for it you’d never notice it.
    02Duck, cowsquatch67, Siblue and 3 others like this.
  20. Apr 23, 2019 at 12:25 PM
    #100
    trajiiic
    Fine...... I'll risk it. I'm at 1,800 miles right now. I'm gonna hold out until 5k.
    cowsquatch67 and TacoOR like this.
