ToyotaCare 10K mi Service / Truck Lifted Now, Any Dealer Issues Expected?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fredfifty, Dec 16, 2015.
  1. Dec 16, 2015 at 11:14 AM
    Fredfifty
    Fredfifty [OP] Back in a Mini
    Dave
    Big Island - SF Bay Area
    99 5 Lug V6
    DJM 3/4 DJM UCA BJ FLIP CALMAX SHOCKS POLYURETHANE SWAY BAR BUSHINGS POLYURETHANE UCA BUMPSTOPS ROLLED FENDERS DJM 4 INCH ANGLED BLOCKS (STEEL) MINI C-NOTCH FROM ROHDE FABRICATIONS MJBTACO LOWPRO BUMPSTOPS CALMAX SHOCKS ROLLED FENDERS
    So im taking my truck in for its second toyotacare service (10k mi). The first time it was all stock, but now when i bring it in for its second service, they will see it now has 6 inches of lift...anybody have experiences with dealers giving them a hard time because its not stock?
  2. Dec 16, 2015 at 11:22 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Shouldn't be.
    10k service has nothing to do with your suspension.
  3. Dec 16, 2015 at 12:58 PM
    Theloden
    Theloden Well-Known Member
    Joe
    Lakes of the North, Michigan
    '23 TRD Off Road
    It's going to depend on your dealer, the one I go to is super chill and never gives me a hard time about anything...although my truck doesn't have anything major done to it. I've had trucks in the past that were modified fairly heavy though, and still the dealer never gave me any problems.
    Crainiac likes this.
  4. Dec 16, 2015 at 1:01 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Why could they possibly give you a hard time about, unless they have midgets working there who wont be able to change the oil due to them being midgets then I don't see a problem?!?
    Mully and Sugar Silva like this.
  5. Dec 16, 2015 at 1:04 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    My truck hasn't been back at the dealership for service since I bought it in Nov 2013
  6. Dec 16, 2015 at 1:07 PM
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    Ditto. Rotate tires is the only thing that would be even vaguely associated. Honestly nothing in the maintenance manual should ever have anything to do with your lift. Where you will run into problems is if you have something start wearing like a carrier bearing, balljoints, transmission issues - then they could start pointing to your aftermarket suspension possibly.
  7. Dec 16, 2015 at 4:12 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    dont even bother.... save yourself the time and pain of taking it to the dealer and simply do the oil change and tire rotation yourself.
    And while you are under there grease your u joints... cus the dealer wont do that for you.
  8. Dec 16, 2015 at 4:19 PM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    Nope. When I had my 10k done, the service manager complimented my truck saying it was tastefully done :cool:
    jdg likes this.
  9. Dec 16, 2015 at 9:58 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Do expect them to put a note in your file about it though. That way if you ever come back for warranty work related to any problems that can be caused by a lift they can say, sorry no dice you had a lift on it, even if you remove it for taking it in. Other than that they will be cool about it, they see it all the time on Tacomas.
  10. Dec 16, 2015 at 10:29 PM
    jdg
    jdg Well-Known Member
    David
    Texas Panhandle
    2015 Tacoma SR5, V6, automatic, 4x4, extended cab
    All the time!!!
    Same here they were just bragging on how it looked now.
  11. Dec 16, 2015 at 11:05 PM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    No worries. A lift doesn't 'automatically void your entire warranty', as is a common misconception. Federal law is VERY much on your side when it comes to a vehicle warranty. If your engine were to blow out in 1k miles (knock on wood), for the dealer to deny your claim based on a lift, they would have to prove in federal court that the lift caused the motor to blow. Everything is legal cause and effect - without that, the dealer cannot flat-out 'void a warranty' based on a modification you have done to the vehicle.
    Reading: http://www.mlmlaw.com/library/guides/ftc/warranties/undermag.htm
    @JeffreyB makes a good point. They will likely put a note in your fille, and if you come back in with a suspension-related warranty issue later, they may use the lift against you. See above about warranties - if they can prove that a lift caused excessive wear and tear to another item, they may have grounds to deny a warranty item.
  12. Dec 17, 2015 at 11:50 AM
    adrenalnjunky
    Can't grease them - Prerunners don't have the grease fitting equipped U-joints. They're the same size and spec as the ones in the 4x4's, just not greaseable.
  13. Dec 17, 2015 at 1:58 PM
    nd4spdbh
    SoCal
    09+ prerunners have greaseable u joints if i am not mistaken
  14. Dec 17, 2015 at 6:32 PM
    adrenalnjunky
    Well that is a big improvement, I had to replace mine at 100K, made sure I put in the greasable kind.
  15. Apr 29, 2016 at 8:39 AM
    Fredfifty
    Dave
    99 5 Lug V6
    i forgot to reply back, but the dealer did not rotate my tires because my truck was high and they did not have the type of lift needed to raise my truck. that sucks...DIY i guess
  16. Apr 29, 2016 at 9:43 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    THIS
    Dealers and their service writers are not created equal. Same goes for a lot of other things in this world. You may have no issues during your 10K visit; then run into all kinds of crap during the subsequent visits if a different service writer is involved or the one used during your 10K visit is in a different mood that day. It's impossible to know what they're going to say until you take it in.
    Remember - you DO NOT have to take your Toyota to the dealer you purchased it from for either warranty work or Toyota Care.
  17. Apr 29, 2016 at 9:51 AM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    Yep. Even when it comes to warranty issues that are completely unrelated to suspension, they will try and pin it on that. Just so you know.
  18. Apr 29, 2016 at 9:53 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Keep in mind this is not a criminal trial, Toyota doesn't need to prove beyond a reasonable doubt. A lift and larger tires can reasonably put greater wear and tear on suspension and driveline parts (wheel bearings, front diff bearings, CV joints, driveshaft carrier bearing...), and there are plenty of "experienced industry professionals" at the dealer and at Toyota who can attest to it.
  19. Apr 29, 2016 at 11:20 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I like how people get overly concerned about a $20 oil change after spending $30k on a truck and $5K+ lifting it.
    T4RFTMFW and melikeymy beer like this.
  20. Apr 29, 2016 at 2:19 PM
    Lester Lugnut
    There are no Toyota dealers in my area that charge as little as $20 for an oil and filter change, but your point is well taken.
