Toyotas driving in the Snow Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Willy-N, Dec 13, 2021.
  1. Dec 27, 2021 at 6:57 AM
    #141
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    About using ANY form of cruise control in snow or heavy rain- just don’t.
    skippyscage and shakerhood like this.
  2. Dec 27, 2021 at 7:02 AM
    #142
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    If only the earth would warm up so we just lived in the desert.
    Willy-N[OP] likes this.
  3. Dec 27, 2021 at 8:49 AM
    #143
    iza586
    iza586 Well-Known Member
    2021 Tacoma TRD Sport
    TRD leveling kit 4rp wheels 265/70/17 ko2
    Hey, bit of a truck noob here but is there a speed I should avoid driving above in 4x4? I was driving the freeway in MT and often forgetting to put back in 2wd when conditions improved and found myself going 75 at times in 4wd. Is that bad for the engine/transmission? Owners manual didn’t help me with this question.
  4. Dec 27, 2021 at 8:57 AM
    #144
    techtacoma
    techtacoma What's rattling now?
    Oregon
    2020 Tacoma TRD Sport 4x4
    I've seen a lot of comments saying to not use it above 55 MPH because of the transfer case. But there is no documentation anywhere to support that claim (that I have found) on the newer Tacomas. I have driven in 4WD at about 75 MPH for an extended period of time. I also know different vehicles/older ones would limit you to a certain speed when in 4WD but the new Tacomas don't do that anymore. Might be advancements in the system.
    If anyone knows otherwise, I'd love to see paperwork from Toyota (or any reputable source) about this!
  5. Dec 27, 2021 at 9:16 AM
    #145
    Willy-N
    Willy-N [OP] Well-Known Member
    Mark
    Eastern Washington Stat
    2022 Silver Tacoma TRD Off Road
    Last night the winds gusted to 52 MPH with a -34 below zero wind chill. Steady winds at 35+ and temps of -9 below zero! Just to darn cold to go out and play on the tractor busting drifts. I could make a ton of money right now if it wasn't so friggen cold out with the winds!! Don't need money that bad! Posted a picture before of it and my head lights had snow on them from just sitting there. I had put the Rain-X on them before this. Little later it just fell off the lights and Emblem but not on the rest of the grill. So it must help some? Supposed to slow down and warm up some in a few days??
    On the driving in 4x4 at speeds if there is ice or snow on the road it is in 4x4 and I just drive at a safe speed depending on the conditions. It can be over 60 Plus MPH or under it even in old 4x4 rigs. My 76 4x4 1 ton Chevy I could do 60-65 and pull it in any time I needed in High Range if my Hubs were locked in which are during the winter most of the time. Nice part it went in right off! My 2022 TRD takes a while to do it need to make sure I pay attention and not find out in a blind curve I should have done it earlier!
    Sierrahunter likes this.
  6. Dec 27, 2021 at 9:51 AM
    #146
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I think it is fine to go the speed limit in 4WD. There is a limit where if you are over it will not allow you to change to 4WD and that is very unpleasant when you hit a sudden snow squall with limited visibility and sudden icy roads. So put it in 4WD if needed and stay in even if shorter patches of time when you don’t need it.
    techtacoma[QUOTED] likes this.
  7. Dec 27, 2021 at 11:00 AM
    #147
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Agree with everybody else…. The road conditions will limit your speed before the drivetrain does
    skippyscage and Willy-N[OP] like this.
  8. Dec 27, 2021 at 11:46 AM
    #148
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    I just installed the Diode Dynamics SS3 pro fogs. Definitely plug and play. I had them installed and aimed in about 30-45 minutes. Take the grill off to install them as most people are going through the fender liner which is a pain in the ass.
  9. Dec 27, 2021 at 12:56 PM
    #149
    Willy-N
    Mark
    co blower.jpg Nice Lights!!! This is what I have been dealing with the last 24 hours at my Home. This RAWS Weather Station is about 2 miles same elevation. Look at the reports each our. Should let up a little tomorrow?? KRAMER (noaa.gov)
    Least the County Snow Blower went thru just now!
  10. Jan 6, 2022 at 12:08 PM
    #150
    Regular cab joe
    Regular cab joe New Member
    Elb
    Minnesota
    06 reg cab MT buckets
    5100s - 265/75/16
    Putting the sand bags right behind the cab vs over the axle makes a huge difference in a reg cab truck. I also move my spare to the front of the bed in the winter. Strap down to rings I installed on bed bolts.
  11. Jan 6, 2022 at 1:52 PM
    #151
    Willy-N
    Mark
    First time off road in the snow today. Unimproved tore up chunky snow to get my front tire off my tractor. Road out in a Dodge 4x4 Dulley back in with my TRD and wow what a difference I could fly in and out the Dodge was almost getting stuck! I really love this truck now! Nothing in the bed going in and a tire coming out! Got my 4x4 tractor stuck bad front tire in a hole all 4 tires spinning. Hooked the TRD to it my Daughter at the wheel. Low range it pulled me out all 7,000 lbs plus and the tires did not even spin on packed snow. You could hear them squeaking on the snow when it moved. Great traction!! Going back out to the tractor now tire is here.DSCF8037.jpg DSCF8041.jpg DSCF8033.jpg
    Stocklocker and Westsideott like this.
  12. Jan 15, 2024 at 6:11 PM
    #152
    eduardofuria
    eduardofuria Well-Known Member
    Eduardo
    my Tacoma on the ice, i was able to drive it safely.
    shakerhood, grogie and mic_sierra like this.
  13. Jan 16, 2024 at 4:05 AM
    #153
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    It’s not a great idea to use cruise on the snow.
    But, you can still use it in the old school mode when the sensor is covered.
  14. Jan 16, 2024 at 4:34 AM
    #154
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    Absolutely agree. But…
    Watch out for the fuzz. When I was a young buck, I had a new to the force make an example of me. The violations they can choose from to pile on for simple donuts can be dead serious. After the fact I came to find he was pissed off having previously warned (other) kids in that lot earlier that night. It very nearly changed the trajectory of my whole life, no hyperbole.
    musicisevil likes this.
  15. Jan 16, 2024 at 5:29 AM
    #155
    TOMRR
    TOMRR Well-Known Member
    Tom
    Mass
    2016 TRD OFFROAD, DCSB, AUTO, BLAZING BLUE, PREMIUM JBL TECT.
    Stock TRD OFF ROAD DCSB AUTO JBL TECT. Bed Mat Heated and turn signal mirrors Wet Okole Front Seat Covers Prodigy Brake Controler Front Skid Plate Power Wagon Badge Tint Driver and Pessenger door windows Inchannel window vents
    doublethebass likes this.
  16. Jan 16, 2024 at 7:13 AM
    #156
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Snow and ice buildup is a problem with most lights now, LED is much worse than the standard Tacoma lights.
    As far as your travel issues, a few things can help. Weight in bed is a must, 300# works well.
    Buy some chains, 6” of snow is a lot to try to push through. They are a requirement to have on some mountain passes out west.
    Speed is NOT your friend. If the truck is shifting a lot, put the trans in a lower gear. The shifting often will break the rear loose.
  17. Jan 16, 2024 at 8:02 AM
    #157
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR iForce Max
    I can attest to the shifting issue. I used to travel regularly over Rogers Pass (on MT200 between Missoula and Great Falls MT). I was more impatient in my youth and decided to pass a semi in the ice and snow. I really did not think it all that slippery. I was in a 2005 Chevy Colorado (with a 220-hp, 3.5-liter five-cylinder!) with four sandbags over the axle. I was in 4x4, but as I passed that semi I hit some deeper snow and the transmission downshifted. The wheels cut loose, and I lost control. I had to make a decision about whether to slip under the semi or try to steer into the opposite oncoming lane. The road was empty so I took the oncoming lane. The result was taking out a road side reflector post and high centering on a snow bank.
    Cell service was sketchy, but the trucker had a CB and called the state patrol. The officer told me he had to give me a ticket. "Too fast for conditions".... "do you agree?" Uh, look at my truck! He pulled the road side post back in position, issued the ticket and called a wreaker. When I went in front of a Missoula County judge to explain the situation, she ended up giving me a ticket for $20, warning me that driving too fast for conditions can mean driving school and potentially a night in jail depending on the circumstances. (After I agreed, she told me "You did the right thing... keeping the damage to your own vehicle.... drive more carefully!"). I felt lucky. And it was a company leased vehicle. So I got to drive a loaded Ford F150 while it was being repaired. I always locked the transmission gear when I was travelling up or down any snowy pass after that. Be careful out there.
  18. Jan 16, 2024 at 10:57 AM
    #158
    Evan_P
    Evan_P Well-Known Member
    Evan
    Hillsboro OR
    2020 Voodoo Blue TRD Off-Road
    Mine handles the snow very well.
    TOMRR and Cipher94 like this.
  19. Jan 16, 2024 at 11:11 AM
    #159
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    unless the business pushes for it, cops can’t ticket on private property like parking lots.
  20. Jan 16, 2024 at 11:13 AM
    #160
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I’ve drove that pass many times when stationed at Malmstrom. It’s been quite a while…..left in 96
    dleithaus[QUOTED] likes this.
