Toyota's paint sucks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06SR5canada, Aug 14, 2011.
  1. Aug 14, 2011 at 8:01 AM
    06SR5canada
    06SR5canada [OP] Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    so what are you guys doing about the bazillion paint chips?
    just rediculous how easy this stuff chips off, my old 1998 blazer has maybe 2 or 3 and i was running offset rims and constantly sprayed the sides with dirt and mud and the paint wouldnt even scratch, let alone chip.
    guess toyota assumed these trucks would never see dirt or mud?
    /rant
  2. Aug 14, 2011 at 9:09 AM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    El Cajon, CA
    Blue '06 Prerunner TRD Sport
    LED Spyder Tail Lights, Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear 5125s, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 33x12.50R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack, Glassworks Front Fenders, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, MBRP Catback Exhaust, 20W PA Speaker, 2 Meter Radio, AFE Stage2 CAI, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper
    I went ahead and bought some SWB touch up paint and use that every here and there when I think it's really needed.
  3. Aug 14, 2011 at 9:19 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    It's all newer vehicles actually. Since they went water based from oil this stuff chips if you spit on it.
  4. Aug 14, 2011 at 9:20 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I get pelted with high speed road dust, extreme wear and tear is expected
  5. Aug 14, 2011 at 9:20 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Invest in 3M Paint film
  6. Aug 14, 2011 at 9:22 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1
  7. Aug 14, 2011 at 9:23 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    :rofl:
    but seriously, I should take a picture of my body kit, theres one spot specifically the front tires hit dirt into, it's already through the clear coat the paint the primer and starting into the plastic
  8. Aug 14, 2011 at 10:19 AM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    ok, so what do you do if the chip has started to rust? obviously you would sand it, but what do you use? ive seen something along the lines of a sanding pen....anyone use those?
    also do you clear coat a chip repair?
  9. Aug 14, 2011 at 11:38 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I noticed yesterday the seams at the front edge of the rear fenders are getting the rust colored line. They will need some attention.
    Also, the paint used for plastic does not wash clean. So far the only wax or cleaner to make the grill white, or the other plastic painted stuff white again is ToyoGard cleaner polish.
    PK
  10. Aug 14, 2011 at 12:10 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    just have keep them clean and wax them more often, especially not garaged. My new truck's paint looks good so far, (garaged kept) JUST a few chips along the bottom. I had a older, non clear coat Toyota and the paint came off every time I waxed it, (Showed on the towels) but it still kept shinning as long as I kept up on the wax.
  11. Aug 14, 2011 at 1:04 PM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    tough to wax here with no garage most of the year, it sucks.
