Toyoteclift help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jamart5, May 19, 2014.
  1. May 19, 2014 at 4:43 PM
    Jamart5
    Jamart5 [OP] HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Ok so I'm new to the forum I recently purchased a 14 Tacoma DBL CabTRD 4x4. I recently installed a toyotec bilstein 5100's 3 inch lift. My question is what setting should my shocks be in the front? I can still see the 2 notches from the top of the shock. Can I raise it to the top notch without having any issues? I've also read that I have to install a 1/4 spacer on the drivers side for correction. Any help will be greatly appreciated.
  2. May 19, 2014 at 5:01 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i wouldn't recommend it, its set there for a reason to match those coils.
    anything over 2.5" should have new upper control arms to adjust the caster angle and anything over 3" is WAY too hard on your CV joints.
    you'll also start preloading the coil causing a stiffer ride.
  3. May 19, 2014 at 5:19 PM
    Jamart5
    Juan
    SETX
    '16 4Runner TRD
    So if I install new uca's will I be able to raises the front more? The front of the truck sits lower than the back when I did the lift they installed a 2 inch aal. I'm running 285/65/18 nitto trails on 18x9 fuels with -12 offset I just want it to look level.
  4. May 19, 2014 at 5:33 PM
    eliasj7
    eliasj7 Well-Known Member
    Elias
    Beaverton, OR
    2013 Tacoma TRD Offroad
    5100's w/ OME 885X, LR UCA's, OME Dakar Leaf Springs w/ OME Nitrochargers. Grillcraft MX Grill w/ white grill trim. AFE Intake. Redline Tuning Hood struts. ADD W1 Oil Catch Can. TRD Cat Back Exhaust.
    Like sr5vic said anything over 3 inches is going to put stress on your CV joints and aftermarket UCA's will only help with getting your caster into spec. How much higher is the rear?
  5. May 19, 2014 at 5:42 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Not using the notches on the 5100s. I'm guessing you have the eibach springs with them, not supposed to go higher than the first notch from what I've read. You could add some top plate spacers, either 1/4" or 1/2" to get a little more lift. Have you measured how much lift you actually got from the kit? Even with new UCAs, which you'll likely need if you go higher, I wouldn't go higher than 3".
  6. May 19, 2014 at 5:44 PM
    Jamart5
    Juan
    SETX
    '16 4Runner TRD
    Maybe 1" really haven't measured It. I might just have to take the 2 inch aal and install a 1 inch I guess
  7. May 19, 2014 at 5:47 PM
    Jamart5
    Juan
    SETX
    '16 4Runner TRD
    How can I post a pic on here so y'all can see it?
  8. May 19, 2014 at 5:49 PM
    bjboucher
    Brad
    San Antonio, Texas
    You only got 1" of lift? Are those new springs or are they new/upgraded springs? If they're the stock springs, you can crank the 5100s up to the top notch. Expect a fairly stiff ride though. If they're new springs, I find it hard to believe you only got 1" of lift.
  9. May 19, 2014 at 5:50 PM
    bjboucher
    Brad
    San Antonio, Texas
  10. May 19, 2014 at 5:55 PM
    eliasj7
    Elias
    Beaverton, OR
    I think he's talking about the height difference between the front and rear. You have a 2014 Taco I would give some time before you change out your AAL the rear might settle in a bit.
  11. May 19, 2014 at 5:57 PM
    Jamart5
    Juan
    SETX
    '16 4Runner TRD
  12. May 19, 2014 at 5:57 PM
    Jamart5
    Juan
    SETX
    '16 4Runner TRD
    I hope this helps.
  13. May 19, 2014 at 6:01 PM
    Jamart5
    Juan
    SETX
    '16 4Runner TRD
    Yes height difference sorry for the confusion as far as the lift goes it's all new springs and shocks combo just take old ones off and bolt new ones on.
  14. May 19, 2014 at 6:09 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    03 Tacoma SR5
    3" lift Freedom Off-road adjustable coilovers 5100’s out back with AAL TRD Pro wheels w/ 285.75.16 KO2’s Freedom Off-road UCA’s 4xInnovations front bumper (on order!)
    Do you have eibachs on bilsteins?
    Since you have a 2nd gen there are 4 settings on the bilsteins (stock, .85", 1.75", 2.5"). The .85" setting paired with eibach as should have given you 2.5" of lift then to get the full 3" lift you'll need the 1/4" top plate spacer to give the extra .5" of lift needed. You don't want to exceed the .85" setting with eibachs or else there will be too much precompression and too much lift if you were to bump it up to the 1.75" setting.
    With eibachs...
    1st setting = 1.65" lift
    2nd setting = 2.5" lift
    3rd & 4th = don't do it
    For the full 3" get a 1/4" top plate spacer.
  15. May 19, 2014 at 6:14 PM
    Mainmoe02
    Moe
    Austin, Texas
    03 Tacoma SR5
    Just saw your last post... Did it come with a top plate spacer? Truck looks awesome btw
  16. May 19, 2014 at 6:16 PM
    Jamart5
    Juan
    SETX
    '16 4Runner TRD
    I believe it's on the second setting because I can clearly see the extra 2 notches on the shock. Will I need new ucas if I install a 1/4 spacer? Will a 1/2 spacer be too much? Again thanks for all the help.
  17. May 19, 2014 at 6:20 PM
    Jamart5
    Juan
    SETX
    '16 4Runner TRD
  18. May 19, 2014 at 7:09 PM
    Jamart5
    Juan
    SETX
    '16 4Runner TRD
    Would I need to install 1/4 inch spacer to both sides?
  19. May 19, 2014 at 7:50 PM
    Mainmoe02
    Moe
    Austin, Texas
    03 Tacoma SR5
    I've read too many stories of people needing UCA's after going w/ 3" lift, especially on a 2nd gen. So I'm gonna say you'll probably want to get them for alignment and tire wear sake.
    Did the coils/ shocks come preassembled? How much lift did they give?
    If your at 2.5" lift then yes, a 1/2" spacer will put you at 3.5" lift and your CV's will be screaming. A 1/4" spacer would be perfect and put your right at 3". If you have the driver side lean then see if toytec makes a 3/8" top plate spacer. I know they have a top plate spacer that gives about 3/4" lift which would help compensate for the taco lean. Depending how bad the lean is on your truck maybe a 1/2" top plate spacer wouldn't be bad for the driver side only. Kinda depends how much your truck settles after a couple months.
  20. May 19, 2014 at 7:53 PM
    Mainmoe02
    Moe
    Austin, Texas
    03 Tacoma SR5
    Ok I just saw the link you posted about the setup you have. If that's the suspension you have then it gave you a full 3" lift. All you would need is the 1/4" top plate spacer for the driver side only.
    Edit: you should already have a 1/4" top plate spacer on both sides. So what you want to do is take out the driver side 1/4" TPS and replace it with a 1/2" TPS to compensate for the taco lean. Although you may need longer top plate bolts which would require you to disassemble the Coilover to install the longer bolts then reassemble with the thicker TPS.
    Sorry if I'm getting repetitive, just trying to thoroughly explain.
