Toytec 1/4 spacer for taco lean
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BronsDaGreat, Feb 14, 2014.
  1. Feb 14, 2014 at 4:00 AM
    BronsDaGreat
    BronsDaGreat [OP] Well-Known Member
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    6" FabTech Lift 20x12 Fuel Hostage Wheels 33x12.5 Toyo M/T Camburg Uni's UCA Spintech Muffler AppRadio 3 BHLM Wet Okole Seat Covers WeatherTech Floor Liners WeatherTech Vent Visors 6000k HID Headlights and fogs All Lighting Changed To LED AntennaX 13" Antenna Ceramic Tint K&N Drop In Filter Fully Debadged Blacked Out Emblem
    I'm getting conflicting answers regarding installing this spacer.. Question is can the toytec 1/4 spacer be thrown on top of the spring assembly or do you have to compress the spring, disassemble, and put it underneath the top mount? I'm thinking about correcting this lean but if it requires disassembly Ill probably leave it as is.. Thanks guys..e8e4ehaq_af089644668e35a5b79b020f2077a4b942fc1ab7.jpg
    mahaloTaco likes this.
  2. Feb 14, 2014 at 5:19 AM
    high voltage taco
    high voltage taco Well-Known Member
    Monticello, Ky
    05 TRD 6 speed 4x4
    so far, URD throwout bearing kit(sleeve), weathertechs, 285/70/17's on Ion 17x9 and OME 885s and Dakars and nitro sports. BHLM
    Just put one in mine couple weeks ago and it goes on top of the top hat. No need to take apart the spring. I still have that lean like yours in the back though. I'm thinking of putting some small spacer under my drivers side leafs.
  3. Feb 14, 2014 at 5:29 AM
    timmytoast
    timmytoast Card-Carrying Illuminati Member
    Prison City, CA
    2013 SR5 4x4
    Black Plastiderp Front Emblem and Grille Surround, Relocated Horns, Bed Mat w/ bolt mod, Precision Fit seat covers, Anytime Fog Light Mod, Console and Glove Box Organizers, DIY Washable Cabin Air Filter, Pop N Lock Tailgate Latch, K B Voodoo Bed Brackets
    Maybe this will help. The image is from another thread on here.
  4. Feb 14, 2014 at 5:39 AM
    BronsDaGreat
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    Damn man I thought by putting the spacer it would fix the rear! How long did it take you to install the spacer
  5. Feb 14, 2014 at 5:43 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Hold on..Your worried about the rear? You have the baisc 6" fabtech lift..If your struts we put back on the correct side they came off (springs have slightly different heights which are marked) then your completely fine. The 1/4" is useless in your case
  6. Feb 14, 2014 at 5:49 AM
    high voltage taco
    Monticello, Ky
    05 TRD 6 speed 4x4
    1/4 spacer fixed my front but my rear still looks like yours. I have dakars in the back. Didn't take long to put it in but I was doing wheel bearing and diff bushing all at once on that side so I had to pull it out anyway.
  7. Feb 14, 2014 at 5:52 AM
    BronsDaGreat
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    I'm changing out my entire suspension within the next couple months so I can fix the front with coilovers but the rear I don't know!
  8. Dec 21, 2014 at 4:01 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Did you get a mixed + , - set ?
  9. Dec 21, 2014 at 4:04 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    could that be more of a stereotypical HI rig?
    and technically if you correct the lean in the front side to side the rear should move the same amount.
  10. Dec 21, 2014 at 8:21 PM
    OZ-T
    Peter North
    British Columbia
    You can get an OME trim packer for the rear from Wheelers , it's essentially like a flat axle shim
  11. Dec 21, 2014 at 8:39 PM
    OZ-T
    Peter North
    British Columbia
  12. Jan 15, 2015 at 11:21 AM
    TRDFEVER
    TRDFEVER Member
    Adam
    Fort McMurray
    SR5 TRD SPORT
    Billet Grille, Anzo CCFL Halo Projectors, Blackout TRD Badge
    is there always a lean on driver sides with lifts?
  13. Jan 19, 2015 at 1:50 AM
    BronsDaGreat
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    Nah its just more obvious when lifted.. Stereotypical HI rig... smh...
  14. Jan 19, 2015 at 1:57 AM
    BronsDaGreat
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    The spacer actually corrected my issue front and back..
    DNAVES likes this.
