Toytec 1/4" spacer need longer studs?!
Discussion in 'Suspension' started by r12rex, Jul 7, 2009.
  1. Jul 7, 2009 at 7:51 AM
    r12rex
    r12rex [OP] Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    Hey guys,
    About to put on my billy 5100s set to 2.5 and also purchased the toytec 1/4" spacer to correct the infamous taco lean. I was wondering if the stock studs on the top hat are sufficient to use with the spacer? Are you guys using longer studs?! Thanks!
    Kind Regards,
  2. Jul 7, 2009 at 10:08 AM
    spearhead
    spearhead Taco Supremist
    Winston Salem NC
    09 4DR Mag Grey 4WD Sport
    TRD CAI Eibach Springs 5100s all around Front set to .85 Toytec AAL
    Whats up Ryan
    Very interesting that you ask this as I just (2 weeks ago) had this done and the installer claimed that the studs were too short to add the same .25 Toytec spacer. He had already installed the billys so I was not able to get a visual on what he was trying to tell me but he was questioning putting a spacer on just one side from the get go.
  3. Jul 7, 2009 at 10:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What year is your truck? If its a second gen ( '05 + ) then you should be fine to add a 1/4" spacer without needing longer studs.
  4. Jul 7, 2009 at 11:09 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I needed longer studs with a half inch spacer, not sure what the 1/4" will leave you as far as threads go.
  5. Jul 7, 2009 at 12:07 PM
    spearhead
    Winston Salem NC
    Thanks Chris, I'm 2nd Gen, and what you indicated has been consistent with several lift write ups I have come across, I thought the installer was just full of BS until seeing Ryan's post.
  6. Jul 7, 2009 at 1:59 PM
    r12rex
    Chris,
    05 Taco here. :) Thanks for all the feedback guys. Looking forward to posting pictures. :devil:
    Kind Regards,
  7. Jul 7, 2009 at 2:05 PM
    Toyota Man
    Toyota Man Toyota Man
    Oregon, Centeral Willamette Valley
    11' DCSB TRD super charged off road
    TRD super charger, TRD cold air intake, and exhaust. Downey coil overs coming soon
    Hi, thought I would give you my 02 cents
    I had a revtek lift kit installed and it has the 1/4" alum. spacers that fit on top of the coils. The kit did not have the replacement studs and I called Revtek and they said that on 05 and newer that they were not needed and will not put them in on 05 and newer kits from now on. I watched when they were putting the kit together and the stud did not have much thread left, but had enough for a good bite on the 3 to 4 threads that were left, just not gobs of it left over like in stock form. Les Schwab here on the west coast is the one who put the kit together for me and they said that they dont usually change studs anyway.:) If you have anymore questions feel free to ask.
  8. Jul 7, 2009 at 3:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    3 to 4 threads is not going to offer the nuts a good purchase. I would get longer ones.
  9. Jul 7, 2009 at 11:34 PM
    StaticTaco
    StaticTaco Well-Known Member
    Mitch
    Oahu
    2011 SR5 4WD
    is the lean really all that noticeable? or is it comparable to what the lean is on stock suspension? im about to lift my truck with 5100s, blocks, and tc ucas, and was curious if i should invest in this spacer.
    if its not all that noticeable or bad, i'll just leave it.
  10. Jul 8, 2009 at 5:13 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I can't notice it at all on mine. I broke out the tape measure though and sure enough, drivers side sits 1/2" lower than passenger side. Since the 5100s are going on, I got the spacer to correct the lean.
    I guess its all personal preference. If you don't notice it, then maybe its not important. The tape measure told me what I needed to know though...
  11. Jul 8, 2009 at 5:26 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Same setup here. I used the spacer on driver side & you can't see threads on top of the nut but you can see all of the angled top part of the stud sticking up thru the nut. Looks like threads made it all the way thru the nut, just not up on top where you can see them. Had no issues with it. There should be no opposite force on it anyway unless you plan on flying your truck or when you jack it up off the ground. I'll see if I have a pic of that area close up enough to tell..........nope, pics are on PC at home.
  12. Jul 8, 2009 at 6:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your good then. As long as the threads are mostly thru the nut, all should be good.
  13. Jul 8, 2009 at 9:44 AM
    StaticTaco
    Mitch
    Oahu
    2011 SR5 4WD
    hey thanks for the info, I guess I'll be leaving it. I can't really notice the lean on stock suspension so I guess it's not a very big deal. I just hope someone doesn't come up to my truck after the lift and take a tape measure
    to it haha thanks though, can't wait for my lift to go on :)
  14. Jul 8, 2009 at 11:35 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I used the longer studs when I had the billy 5100 lean.
  15. Jul 9, 2009 at 3:42 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It's the taco lean. They lean with anything but fully adj coilovers or using the spacer.
  16. Jul 9, 2009 at 2:35 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Yes I'm aware.
