Toytec 3” lift anygood?
Discussion in 'Suspension' started by Dominator0205, May 30, 2018.
  1. May 30, 2018 at 11:46 AM
    Dominator0205
    Dominator0205 [OP] Member
    Dominic
    2005 Black Tacoma 4x4 SR5 Base
    Flowmaster 50 series delta flow, Kenwood Deck, Weather tech All weather mats, More to come
    I want to get an affordable 3” lift on my Tacoma so I can fit 33’s on it, I was thinking this lift kit is good but wanted some opinions since it’s on the cheaper side. I would put bilsteins 5100 in the front on the lowest setting in the future but not rear. I was originally wanting to get a rough country but I was reading on this website they are bad and this lift kit is not that much more expensive and I feel like it’s a way better option.
    Link: https://bilsteinlifts.com/shop/toyo...t-coils-rear-options-2005-2016-toyota-tacoma/
    ChadsPride likes this.
  2. May 30, 2018 at 2:01 PM
    Dominator0205
    Dominic
    Ok what do you think is the max tire size I could fit on that then?
  3. May 30, 2018 at 3:07 PM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    I have the same lift currently. I fit 33s just fine with a little nip cut off of the fender flares. Just keep in mind that the ride quilty will be worse than buying an actual suspension setup. That's why I just ordered all new suspenion for mine. 5100s on all four corners, ebiach springs up front and dakars in the rear. Total came up to $1,200 and I would say that you would be better off saving up your money for a setup similar to mine.
  4. May 30, 2018 at 3:59 PM
    Dominator0205
    Dominic
    Yah I think I am going to go with 285/70/r17 but I ride on the street most of the time. I was gonna get the shocks for the front but not for the back
