Toytec 3" lift question
Discussion in 'Suspension' started by 09whtaco, Oct 11, 2009.
  1. Oct 11, 2009 at 3:41 PM
    09whtaco
    09whtaco [OP] Member
    Warminster,PA
    Tacoma Sport
    I'm about to order the 3" lift kit from Toytec my question is with the front spacers and the rear block option does it include new u bolts? It doesn't specify or are they not needed? Thanks in advance.
  2. Oct 11, 2009 at 3:46 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I would not order the spacer lift or blocks. Harsh ride and the least quality of a lift so to speak. If you are on a tight budget look into getting the OME coil lift with a rear aal. That is a nicer lift. Only thing with the coils is that you will need to buy either Bilstein 5100's for the front, or the front OME shocks.
    Or, a very popular lift is the aal for the rear and just the bilstein 5100's. These shocks will fit on your stock coils and can be adjusted to different height settings. The highest is 2.5".
    Either way, both of these are much better than spacers. Most people that have a spacer lift end up switching later. Plus, you have a new 2009. Dont be stingy with a nice truck! lol
  3. Oct 11, 2009 at 3:55 PM
    09whtaco
    Warminster,PA
    Tacoma Sport
    so if i go with the front coils and rear aal i would need new shocks for the front bec the coils will be longer than the oem shock?
  4. Oct 11, 2009 at 3:57 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yes you have the right idea. Whats your budget like? Are you looking to get a lift and have the truck level? Or get a lift and have the rear sit higher a little like it does now?
  5. Oct 11, 2009 at 4:06 PM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    get the ultimate lift kit if its within ur budget i love mine
  6. Oct 11, 2009 at 6:01 PM
    09whtaco
    Warminster,PA
    Tacoma Sport
    I want to get a 3" lift and I want it level, would a front spacer and rear aal's be a better ride that a rear blocks?
  7. Oct 11, 2009 at 6:05 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    x 1,000,000 lose the spacer idea
  8. Oct 11, 2009 at 6:05 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    You should just save for the coil lift than with the shocks. You will more than likely regret the spacers. But definitely the aal for the rear.
  9. Oct 11, 2009 at 6:10 PM
    09whtaco
    Warminster,PA
    Tacoma Sport
    so if i get the 3" lift with the coils and the rear aals I would also order the front ome shocks for the longer coil? would i need longer brake lines or anything else? or should i just go with the ome suspension lift kit with the top place spacers?
  10. Oct 11, 2009 at 6:22 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea you would buy the ome shocks. You do not need the longer brake lines. I have a 3" rear lift and I don't use them. However you can if you want. Oh and if you do that with the ome buy the trim packer as well. That is a special ring for the ome shocks thy goes on the driver shock to help compensate for the taco lean.
  11. Oct 11, 2009 at 6:23 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    If you can save up and drop the coin on the ome lift kit do that. You won't regret it.
  12. Oct 11, 2009 at 6:25 PM
    09whtaco
    Warminster,PA
    Tacoma Sport
    do i buy 2 trim packers for both front shocks
  13. Oct 11, 2009 at 6:30 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    No just one. They only go on the driver side shock. I can tell you a better in depth explanation tomorrow. I'm at a gathering so it's hard to type.
  14. Oct 11, 2009 at 6:32 PM
    09whtaco
    Warminster,PA
    Tacoma Sport
    one more question would i need upper control arms rite away for alignment purposes
  15. Oct 11, 2009 at 6:35 PM
    jwhelan
    jwhelan Well-Known Member
    JW
    Dallas Texas
    05 TRD Silver
    TRD PreRunner, 5100's on all four fronts @ 1.75, AAL, SP performance rotors, hawk pads, 17" FJ Cruiser wheels P/C black, 265/65/17 BFGR Rugged Trails, BHLM , painted grill, blacked out emblems
    So AAL in the rear and bilstein's on all four corners I'm thinking might be a good option for PreRunner? I was kind of thinking the Toytec Ultimate for mine...sorry didn't mean to hijack.:rolleyes:
  16. Oct 11, 2009 at 6:49 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Not right away. If you want to wait, get it aligned after you put the lift on. Then save up and buy them. The longer you wait the more the inside of your tires will wear down.
    Depends on what type of offroading you want to do. If you have the money for an ultimate lift I say go a different route. Since you have a prerunner you can run spindles. Those give you either 3.5" or 4" depending on what brand you buy. Then add something to the rear.
