toytec 3" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blue_tacoma, May 1, 2010.
  1. May 1, 2010 at 5:33 AM
    blue_tacoma
    blue_tacoma [OP] Member
    Ontario, Canada
    05 TRD SPORT
    3" Toytec AAl with 884 coils AFE Pro dry CAI Magnaflow Cat-back exhaust
    so i just put a toytec 3" lift in my 2005 tacoma double cab, long bed, TRD sport. First of all, I was impressed at how fast the delivery was. I put a AAL in the back, new 884 coils with the half inch aluminum spacer for a full 3" in the front. Also i put a 1" drop kit on the front differential to help out the CV joints. It looks great!! and i still have about a 1" rake, which is good, cause i do alot of towing and payload hauling.
    I was wondering what i could add to the rear suspension to increase payload more, with out putting a huge rake on it?
    But also, after i put the front lift and diff. drop kit in, i noticed a slight vibration in the front end, between the speeds of 30-40mph. i have had the alignment done and its still there. Im thinking maybe its the front drive shaft. cause that is not a big lift for the CV joints. has anyone else had this problem?
    I noticed that there is a gas milage decrease obviously because of the increased angle on the cv joints. is this permanant, or do the CV jonts wear-in at all?
    any input on anything would be great! Thanks in advance
  2. May 1, 2010 at 5:44 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Sounds like you want air bags in the back.
    As for the front drive shaft i guess it could be though i have no idea what that entails. The rear one is a quick fix and increases mpg and power instantly while fixing vibes. (actually I got the best mpg I have ever had in my truck after shimming my drive shaft. 400 mile tank!)
  3. May 1, 2010 at 5:50 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
  4. May 1, 2010 at 5:52 AM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    are you sure its the front that the vibes are coming from? axle shims and carrier bearing drops seem to help with alot of peoples vibes after lifting their truck
  5. May 1, 2010 at 6:01 AM
    jdaniel1463
    jdaniel1463 Active Member
    Maryland
    07 TRD offroad
    How long did that kit take you to put in? I am ordering the same kit monday. Also how does it drive, still smooth?
  6. May 1, 2010 at 7:11 AM
    JODY
    JODY New Member
    Jody
    Canton
    2007 Tacoma D-Cab 4x4
    in progress
    Just installed same lift from toytec, and I have the same problem. I was going to start a thread this morning but you already did. Lots of steering play and vibration at 45-65 mpg. I have not done the diff drop yet.
  7. May 1, 2010 at 7:31 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    You need to order a toytec carrier spacer and possibly some shims.
  8. May 1, 2010 at 7:46 AM
    blue_tacoma
    Ontario, Canada
    05 TRD SPORT
    i Know the vibrations are coming from the front end, because i put the rear leaf in first. Then put the front lift in two days later, and there was no vibration until the front was done. There is no steering play though.
    The whole project took about 6 hours all together. 2 hours on the rear, 4 on the front. The ride quality is good. maybe a little softer on the bumps. haven't taken it offroading yet.
    Which drive shaft were you referring to? when you were talking about shimming?
  9. May 1, 2010 at 8:01 AM
    blue_tacoma
    Ontario, Canada
    05 TRD SPORT
    i could not find any carrier spacers or shims on toytecs website. never mind about the drive shaft question. i didnt notice what you said before.
  10. May 1, 2010 at 8:19 AM
    blue_tacoma
    Ontario, Canada
    05 TRD SPORT
    any recommendations on airbags, the best brand and where to get it?
  11. May 1, 2010 at 9:03 AM
    Razorecko
    http://www.toyteclifts.com/index.ph...ategory_id=64&option=com_virtuemart&Itemid=72
    also the ride is only slightly better than oem because you have the AAL. When i switched over to a full ome dakar rear leaf pack the ride is now like a cadillac. With the AAL and front coils its actually almost stock stiffness in the back and much softer in the front. When you do a real leaf pack with the front coils its soft in the f&r.
  12. May 1, 2010 at 7:18 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    i am refering to the rear driveshaft, the one from your tranny to your diff. when i was talking about shimming i was talking about axle shims which go between your leaf pack and your axle. ill find ya some pics or links
  13. May 1, 2010 at 7:21 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  14. May 1, 2010 at 7:23 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  15. May 2, 2010 at 4:31 PM
    blue_tacoma
    Ontario, Canada
    05 TRD SPORT
    hey thanks for the links to the parts
  16. May 2, 2010 at 4:46 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    you're welcome
  17. May 2, 2010 at 4:51 PM
    Brunes
    Brunes abides.
    Rotorhead
    FWIW- The 884 springs are NOT the Toytec lift kit. They are an OME lift sold by Toytec.
    You can't "increase" payload more just by putting stuff into the suspension- Payload is predicated on brakes, transmission, frame,etc. You might make it handle the weight better...but even that is only to a point. And there is usually a down side to pretty much any mod.
    You can cause vibes in the front or rear by lifting the front. Lifting the front changes the driveline geometry all the way thru....Lifting the rear really doesn't. You need to be really sure of where the vibes are coming from to diagnose/purchase the right parts.
    Good luck ferreting out the vibration issues.
