Toytec 5100s, Studs Spinning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Grakyn, Mar 18, 2016.
  1. Mar 18, 2016 at 2:18 PM
    Grakyn
    Grakyn [OP] Well-Known Member
    Kyle
    Prince George, British Columbia, Canada
    2013 DCLB TRD Sport
    Toytec Ultimate Lift, Leer truck cap, Kenwood D710a ham radio, OTRATTW switches
    Hi guys,
    I am trying to remove some Toytec 5100s and I have got one nut off. The other 5 mounting studs are all spinning. What do I do? I can probably take a grind to the front ones, but will have a hell of a time trying to grind off the ones in the back. Ideas? Has anyone else experienced this?
  2. Mar 18, 2016 at 4:15 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    If I recall, I think the stud has an Allen wrench hole in the top where you can insert an Allen wrench to keep it from turning
  3. Mar 18, 2016 at 4:18 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Are you going to reuse them? If not get a set of vicegrips and put them on the shaft as tight as you can and turn the top nut until it wedges the vicegrips in place
  4. Mar 18, 2016 at 6:38 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Wait before you go and put vise grips on the body, get a rubber strap wrench instead. It should hold well enough and not damage the surface so you can reuse them or resell them.
