toytec adj coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Dec 17, 2009.
  1. Dec 17, 2009 at 9:01 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    How do i put the toyted adjustable coils on the bilstien shocks. do i remove the clip and just set the thread at the bottom?
  2. Dec 17, 2009 at 9:13 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    you move the c clip to lowest setting, put the collar on the shock, place the springs on the collar, compress and put the top plate on.
  3. Dec 17, 2009 at 9:19 PM
    kinkrider101
    santa barbara
    wheels and tires
    what is the collar?
  4. Dec 17, 2009 at 9:25 PM
    08pretaco
    Oliver
    az
  5. Dec 17, 2009 at 9:36 PM
    kinkrider101
    santa barbara
    wheels and tires
    the link wouldnt work
  6. Dec 17, 2009 at 9:36 PM
    08pretaco
    Oliver
    az
    give me a sec
  7. Dec 17, 2009 at 9:38 PM
    08pretaco
    Oliver
    az
    does your stuff look like this? the bottom piece is the collar
  8. Dec 17, 2009 at 9:55 PM
    kinkrider101
    santa barbara
    wheels and tires
    i just have the bilstein 5100s and the toytec adj coils, if that bottom peice is the part with the threads then yes.
  9. Dec 17, 2009 at 9:58 PM
    08pretaco
    Oliver
    az
    set the c-clip to either the lowest or second to lowest setting.
    then:
    then:
  10. Dec 17, 2009 at 10:03 PM
    kinkrider101
    santa barbara
    wheels and tires
    ok thank you that helped alot
  11. Dec 17, 2009 at 10:06 PM
    08pretaco
    Oliver
    az
    no problem. make sure that c-clip is in the slot otherwise another chris4x4 incident will be occuring haha
