toytec adjustable lift question??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Newtaco2012, Apr 17, 2013.
  1. Apr 17, 2013 at 9:20 AM
    Newtaco2012
    Newtaco2012 [OP] Well-Known Member
    Jeremy
    Corpus Christi
    2012 tacoma sport
    toytec adujstable coilover
    when i bought the toytec adjustable lift from a guy he said it was set at 3 inches.. but when i look at it i see alot more thread to make a adjustment? looks like it can raise alot higher? sooo...??
  2. Apr 17, 2013 at 10:35 AM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Is there a question in there, or did you just make that statement for others to read?
  3. Apr 17, 2013 at 11:21 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    if previous owner left it set at what Toytec pre-set it at, the website states it is preset to 2.5-3" of lift. Probably depends on what type of truck (double, access, or single cabs). I wouldn't go cranking it up too high, spring preload will be horrible.
    edit: IIRC for every 1/8" of thread you move up or down on the collar, you lift or lower 1/4" overall. Someone correct me if that isn't the right values, but it was what I remembered.
  4. Apr 17, 2013 at 4:37 PM
    Newtaco2012
    Jeremy
    Corpus Christi
    2012 tacoma sport
    he said there set a 3 inches but theres more thread to go? an its 2012 dbc trd sport
  5. Apr 17, 2013 at 4:42 PM
    caseychai
    caseychai Well-Known Member
    casey
    oahu
    2010 tacoma 4x4
    3 inches is as high as you want to go, if you crank it up more itll start to cause problems. stock tacomas cant be lifted higher than 3 inches without other lift components.
  6. Apr 18, 2013 at 7:09 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Are the CO's installed on your truck ? If your happy with the looks and the ride, I wouldn't start cranking it higher. Things will only get worse.(ride, alignment, etc). Mine is preset at 2.5" and the ride is better than factory.
