Toytec/bilstein coil overs question!
Discussion in 'Suspension' started by xTACOMAx, Jan 13, 2017.
  1. Jan 13, 2017 at 6:36 PM
    xTACOMAx
    xTACOMAx [OP] Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    What's up guys/gals I just bought a set of toytec/bilstein coil overs that are already preassembled and have the 521600 coils that give 2.5" lift and they came with the Toytec aluminum top plate spacer for 3" of lift. They also are set on the bottom clip/setting and was wondering if anyone has ran these before and has anyone adjusted them up one setting to .85" for additional weight? Thanks
  2. Jan 13, 2017 at 7:22 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    One question for you. What is the length of the spring as currently assembled?
  3. Jan 13, 2017 at 7:23 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    They'll ride like shit and void the warranty on your shocks and coils.
  4. Jan 13, 2017 at 7:28 PM
    xTACOMAx
    07 prerunner TSS
    I don't know but I can find out.
    ok thanks I guess I just keep them as they are.
  5. Jan 13, 2017 at 7:39 PM
    01 dhrracer
    Still Shopping
    ToyTec does offer a 620lb rate spring for this application, compressing the 600 an additional 1/2"=.85 lift will add an additional 300lbs preload. May make the ride harsh but provide no more resistance as you travel thru the spring. The 620 will add 20lbs of force required for every inch of travel. I would try what you have first.
  6. Jan 13, 2017 at 9:14 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Hope your fillings are tight
  7. Jan 25, 2017 at 7:15 AM
    Longshoreman
    Longshoreman Well-Known Member
    CA.
    2013 Tacoma off road & tow package
    Toytec coilovers Fabtech uca's Dakars and 5100's in the back.
    I called Toytec the guy told me three inches of lift with the aluminum spacers. I also have a pair of these waiting to go on my 2013. Tomorrow I will receive the OME springs and 5100s for the back. I see you guys don't think very much of Toytech. I am ready for a stiffer ride. I really just wanted to upgrade the suspension.
    OP, did you get 2.5 or 3" out of your coilovers..?
  8. Jan 25, 2017 at 7:19 AM
    xTACOMAx
    07 prerunner TSS
    I've been real busy and haven't had the chance to put them on yet but I hope to get them on this weekend.
    Longshoreman[QUOTED] likes this.
  9. Jan 25, 2017 at 7:22 AM
    Longshoreman
    CA.
    Cool. I have to wait till mid February to get on mine. Now you already have a 3" rough country lift?
  10. Jan 25, 2017 at 7:24 AM
    xTACOMAx
    07 prerunner TSS
    I did, I haven't updated my information stuff on here but I have the Maxtrac 6.5" lift for 2wd only and was gonna remove the spacer lift and put coil overs on.
  11. Jan 25, 2017 at 7:29 AM
    Longshoreman
    CA.
    Okay...so you have already put on aftermarket UCA'S. If I can get away with I will but if I get three inches I gotta get upper control arms. Mo money lol
  12. Jan 25, 2017 at 7:33 AM
    xTACOMAx
    07 prerunner TSS
    No I still factory UCA's and when I had the rough country 3" lift they didn't seem to have any problems getting it aligned.
  13. Jan 25, 2017 at 7:36 AM
    Longshoreman
    CA.
    Thanks. Trying to learn all I can. The more I learn the more I spend...
  14. Jan 25, 2017 at 7:42 AM
    xTACOMAx
    07 prerunner TSS
    No problem! Better to learn some stuff before you buy stuff you don't need lol
  15. Jan 25, 2017 at 7:48 AM
    doorsidedown
    doorsidedown Well-Known Member
    If you have the 2.5" coils with the top plate spacer that equates to a total of 3" of lift, I wouldn't bump it to .85" you're going to max out your CV's.
  16. Jan 25, 2017 at 7:49 AM
    xTACOMAx
    07 prerunner TSS
    I not 4wd so I don't have front axles.
  17. Jan 25, 2017 at 7:51 AM
    doorsidedown
    Ah disregard. Maybe check toytec's recommendation for that coil then, but otherwise, Go for it!
  18. Jan 25, 2017 at 7:58 AM
    xTACOMAx
    07 prerunner TSS
    lol I'm gonna try to get them adjusted and put on if I can. Just some advice since these coils are already under more compression than stock you can't fit a strut/spring compressor from a parts store you would rent in between the coils so you'll have to go to a shop and use there's where it has just the arms that stick straight out to be able to compress the coils.
  19. Jan 25, 2017 at 8:48 AM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    Same story here. just a little rubbing on the tires but nothing a cutoff wheel and some zip ties couldn't fix. Factory UCA's on a 3" RC block lift, aligned no problem.
  20. Jan 25, 2017 at 9:40 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
