toytec bk0510 driver lean spacer question.
Discussion in 'Suspension' started by zoopla, Feb 2, 2013.
  1. Feb 2, 2013 at 3:13 PM
    zoopla
    zoopla [OP] Well-Known Member
    Calgary,Canada
    2011 tacoma trd dbl cab
    K&N cold air intake FXR retrofit/Vleds Avid front bar/side steps 3" Eibach lift
    Hey guys!
    I bought a toytec bk0510 kit and i have a question about the driver side lean. the kit comes with 1/2 inch top plates when purchased for a double cab. i also have a 1/4 inch top plate to correct the drive side lean.
    Now here's the only info i could find about how to install them of toytec's website;
    note#1: Double cab Tacoma’s will need the top plate spacers to achieve an average lift of 3”, and will only achieve an average lift of 2.25-2.5” without the top plate spacers.
    note#2 The ¼” top plate spacer goes on the driver side. DOUBLE CAB TACOMA NOTE: IF USING THE TOP PLATE SPACERS THAT ARE THICKER THAN THE ¼”. TO FIX THE LEAN USE THE ¼” ON THE PASSENGER SIDE INSTEAD OF THE THICKER TOP PLATE SPACER.
    so if i understand; for the double cab i have to use the 1/4'' plate on the passenger side instead of driver and NOT use the 1/2'' top plate provided for the double cabs....why not using both 1/2'' top plate and add the 1/4'' on driver side??? Why do they even sell you two 1/2'' top plates???
    did anyone as done that same lift on a double cab? and how did you do it?
    thanks for the help
  2. Feb 2, 2013 at 3:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Use the 1/2" on the driver side, and the 1/4" on the passenger side.
  3. Feb 2, 2013 at 3:35 PM
    zoopla
    Calgary,Canada
    the way i see it is, if you are only switching plates sides, how can you acheive the full lift since toytec says you need that 1/2'' plate to get a full 3'' lift. if i only put the 1/4'' plate i'll still be short another 1/4 inch.
    So why rouding down when rouding up would make more sens?
    is that the kit you have on your truck chris? is that the way you went?
  4. Feb 2, 2013 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You dont want to stack spacer lifts. I have ran a lift similar to the toytec one, and used the 1/2" on the driver side, and 1/4" on the passenger side. 1/4" isnt gonna be noticable.
  5. Feb 2, 2013 at 3:44 PM
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    I stacked them on the driver side.:eek:
  6. Feb 2, 2013 at 3:59 PM
    zoopla
    Calgary,Canada
    claymore...i was gonna do exactly what you did as it makes more sense...Chris made a good point by not stacking spacers but how long have you got yours like this? and did you need longer bolts to do that?
    toytec; why do you make us buy 2x 1/2'' plates then???
  7. Feb 2, 2013 at 4:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats a bad idea, as the torsional loading on the spacers can cause the bolts to come loose over time. Your risking failure of the spacers by doing this.
  8. Feb 2, 2013 at 4:05 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Im standing by chris......using the 1/4 on passenger side will achieve most of what u need since its the LIGHTER side.......use the 1/2 on drivers side since its heavier.
    Don't stack spacers.
    Call toytec if ya want......let us know what they say.
    if they say to stack em.......then call Sonny at dsm, or Marco at 4wp.....tell us what they say
  9. Feb 2, 2013 at 4:26 PM
    zoopla
    Calgary,Canada
    I'll give them a call to see why they rounded down on this...and why they didn't opted for a 3/4'' on drive side and 1/2'' on passerger side...it's just weird that they sell the 1/2'' plates for both sides when the kit come with the lean correction plate anyways...just weird.
    i'll check back here next week after a call to toytec.
  10. Feb 2, 2013 at 9:11 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    I am curious what they tell you. I called them and they are the ones that told me to do it. I have had it that way for a couple months now with no problems yet. I just checked if the bolts are loose and they are not. Please do post what they say.
    Thanks
  11. Feb 5, 2013 at 11:16 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    That is the way the kit is setup. Some people have stacked the 1/4" spacer on the top plate spacer with no problems at all. If you want to return the 1/2" spacer we can do that for you. Give me a call at 303-255-4959.
    Thanks,
    Julie
