ToyTec boss
Discussion in 'Hawaii' started by MJT SONS, Feb 12, 2020.
  1. Feb 12, 2020 at 1:44 PM
    MJT SONS
    MJT SONS [OP] Member
    Kaipo
    2013 white Tacoma TRD OFFROAD
    I’m to lazy to look up.
    But can someone tell me how to use the tool that came with the kit to lift the front coil over up?
    Thanks
  2. Feb 14, 2020 at 8:41 AM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Have fun PIA need to compressor the spring then you can use the tool to adjust your coil over.
  3. Mar 15, 2020 at 1:12 AM
    GP001
    GP001 Well-Known Member
    TRD OFFROAD
    I just left the adjustment where it was. I had mine for three years and it has been good to me
  4. Mar 15, 2020 at 1:58 AM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    loosen the lock nut (Allan), lube it well and use a cheater bar on the end of it. No need to compress the spring.
    I had to raise mine after adding a hidden winch and a steel skid plate.
  5. Apr 1, 2020 at 1:13 PM
    kpinthebay
    kpinthebay Well-Known Member
    Hawaii ==>>SF Bay Area
    I have the Icons, but it's easier to rotate it if you remove some of the tension. So stick a jack underneath the truck and lift a few inches without getting your tire off the ground. Lube and use a cheat bar.
