Toytec C/O -To UCA or not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ComaTosin, Jan 26, 2009.
  1. Jan 26, 2009 at 3:05 AM
    ComaTosin
    ComaTosin [OP] The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    I will be driving mostly on road with the occasional trip with my dualsport in the back - just easy forrest roads at best. Do I need the UCA to get this thing alligned? I don't think i will miss the additional travle for $600. really not in the budget but i don't want to set myself up for a headache - also i have my wife and son in the truck often and do't want stability issues or shakes on the highway.
    Thanks for any input.
    proposed set up - OME -2.75" spring pack (OME shocks)
    Toytec CO
  2. Jan 26, 2009 at 4:39 AM
    ballon78
    ballon78 Well-Known Member
    Amesbury, MA
    06 CC SR5 TRD
    looking to do the same thing, but 3 inch lift, i wanted spacers because its so easy,mine will be 99% road too, just want 28's under it.
  3. Jan 26, 2009 at 4:52 AM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    I also want 3". I have spacers and blocks right now for 2.5" in front and 2" in back but want a better ride out of the new set up.
  4. Jan 26, 2009 at 4:57 AM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    What block setup do u have, is the ride bad with the spacer set up?? I would think it should ride just like stock since your just lowering the coils down. The only difference, is that i want to do a AAL pack in stead of rear bocks. you have and pics of yours with your current set up. Do the tires rub at all? thank
  5. Jan 26, 2009 at 5:03 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    The answer is no, not really. New UCAs aren't required when you lift. I rode for 20k miles with the stock UCAs and a Toytec 3" 885 lift. I did not experience any abnormal tire wear. Alignment wise, your caster will be out of spec without the new arms and you may get a "loose steering" feeling when driving the truck.
    and Welcome to TW :wave:
  6. Jan 26, 2009 at 5:49 AM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    Thanks Delmarva. That is what i was looking for. hell, i feel like i already have the "loose steering" feeling every since i lifted the truck. I was sort of hoping that a proper lift (c/o and new progressive pack with shocks - not spacers and blocks) would address this problem and make the front end feel more solid and "tight"?
  7. Jan 26, 2009 at 6:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A 2.5" lift will give you about .6* of caster with stock UCA's. Spec. is 2.4* to 3.1*. Thats why your steering feels "loose".
  8. Jan 26, 2009 at 10:22 AM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    And it will always feel that way until I get aftermarket uca's?
  9. Jan 26, 2009 at 10:26 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Yep. The stock UCAs just can't physically be adjusted enough.
  10. Jan 26, 2009 at 11:38 AM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    Is there a popular fit for the Toytec C/O?--- Camburg? Icon? Saw? TC? Looking for economical since the truck does not see much off road action. I'm just looking to improve the ride quality a bit AND increase payload. This set up was well researched but I never considered uca. Doohh! Blows my budget all to hell.
  11. Jan 26, 2009 at 12:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You cant just "Increase" payload. Alot of the payload rating on trucks has to do with drivetrain, brakes, and suspension. By changeing the suspension, and throwing more weight in the truck than what the GVW is, your going to tax the brakes and engine/tranny.
  12. Jan 26, 2009 at 12:51 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    guess I should have been more specific. I undestand that better suspension will not "increase payload". I guess I should have explained that I would like to carry more than 4 sheets of plywood without bottoming in the stops over every bump. Or carry my dirtbikes without riding a wheelie - in the truck!
    Hope the ome springs from wheelers (cs047) will fix this as they have 2 overload leafs. Heard good things.
    Anyway - now that we have cleared that up. Common uca with Toytec?
  13. Jan 26, 2009 at 1:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ok. Well, I recomend the UCA's, as you will be able to align the truck back to factory specs. .6* and my truck wandered all over. Now, with the TC UCA's, my alignment is within spec. and drives great. When towing my boat, the truck is planted.
  14. Jan 26, 2009 at 4:57 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    thanks chris - any forum deals on the TC UCA?
  15. Jan 26, 2009 at 5:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think Toytec and Downsouth Motor sports gives a break to Tacoma World folks. Give Jon at Downsout Motor sports a call. tell him Chris4x4 said to ask about discounts. ;-)
  16. Jan 26, 2009 at 6:27 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    doug at toytec worked up a deal for me for the coilovers and the OME rear springs/shocks but i do not see the TC UCA on his site?
    any contact info for Jon at Downsouth?
    i will try to hunt down a good deal or i can not make this happen.
    thanks guys
  17. Jan 26, 2009 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
