toytec coil over for 5100
Discussion in 'Suspension' started by adam800, Feb 1, 2010.
  1. Feb 1, 2010 at 9:19 PM
    adam800
    adam800 [OP] New Member
    Vancouver
    sport 4x4
    Hello TW
    Newbie Question.
    I am looking to put a 3" lift on my 2007 DC Sport. I am looking at either the OME kit or the ultimate kit from Toytec. My question is, why is the coil on the toytec kit so expensive compared to running 5100 with Eibach or OME 885 springs?
    I understand that the toytec coilovers are a complete one piece deal and is adjustable but would the strut not still be adjustable with OME or Eibach springs?
    Is the extra cost worth it?
    Thanks
    Adam
    Vancouver BC
  2. Feb 1, 2010 at 9:22 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    no its not worth it. buy whichever one you want and can afford
  3. Feb 2, 2010 at 9:14 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    With the Toytec coilover, you can adjust the ride height while its installed on the truck. The base plate for the spring is threaded, so with a spanner wrench you can raise or lower the ride height at any time within minutes. BTW, I believe Toytec uses Eibach springs and Bilstein 5100s on their coilovers, the only thing they add is the threaded adjustable base plate.
    With the standard 5100 shocks you have to take the shock off the truck, use a spring comressor to remove the spring and adjust the base plate. Then reassemble it all.
    With the OME shocks you cannot adjust the height. You buy the height you want and install it, you cannot adjust it (other than adding or removing spacers).
    If you know how much lift you want and you are confident in your decision then get the OME or 5100s and set them & forget them. If you want the adjust-ability then get adjustable coilovers.
  4. Feb 2, 2010 at 9:18 AM
    08pretaco
    Oliver
    az
    thanks for going into depth haha i was lazy
  5. Feb 2, 2010 at 9:20 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2010 4Runner Trail Premium
    you know that you will have to invest in UCAs with a 3" lift right ? Where if you keep it at 2.5" you may not need a UCA that bad ... pros correct me if im wrong !
  6. Feb 2, 2010 at 9:24 AM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    True. My truck started wandering on the freeway with bilstein @ 1.75 and no UCAs. I scrapped that suspension and went with icon coilover and Total Chaos UCAs and have never had a wandering/pulling issue since.
  7. Feb 2, 2010 at 1:31 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    PM sent. :)
