ToyTec Coilover Help
Discussion in 'Suspension' started by Reaper10, Nov 20, 2010.
  1. Nov 20, 2010 at 5:44 PM
    Reaper10
    Reaper10 [OP] Well-Known Member
    Brandon
    Oak Harbor, Washington
    '10 Silver DC 4x4 TRD OR
    Billstein 5100's all around, ToyTec coilovers up front, ToyTec 1.5" AAL in the rear with TSB leaf springs, Light Racing Upper Control Arms, XD Revolvers in Black wrapped in 265/70/17 BFG TA/KOs, AFE Pro Dry S Airfilter, Pioneer AVIC-X920BT in-dash NAVI, Devil Horns by Andres, 14 inch shorty antenna
    OK you suspension experts, I need a little help. Just got done changing my 5100's set at 2.5 to the coilovers from ToyTec. I also threw in some Light Racing UCA's while I was at it. Passenger side is dead on at 23' from the center of the hub to the bottom of the fender. However me being the knuckle head that I am I didn't take the Taco Lean into account and I need to raise the Drivers side up almost an inch. So the question is can I actually adjust these things on the truck or am I going to have to tear the drivers side out again? Bail me out here guys!
  2. Nov 20, 2010 at 6:39 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    yes you can.just take the weight off the suspension and adjust.i drive around the block and come back and re measure just to make sure it set right.
  3. Nov 20, 2010 at 6:45 PM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    Would the extra preload on one side be noticeable or affect the handling ?
  4. Nov 20, 2010 at 6:55 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    i wouldnt think you should even notice since its only maybe a 1/4 inch at most.
  5. Nov 20, 2010 at 6:55 PM
    Reaper10
    Brandon
    Hot damn, that's what I wanted to hear! Thank you very much! I don't have nearly as much work tomorrow morning as I thought.
  6. Nov 20, 2010 at 7:01 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    hey,no problem.and its real easy to do on the truck.good luck and enjoy the new set up.
  7. Nov 20, 2010 at 7:35 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    oh, and reaper, im no expert.just try and help when i can.:D
  8. Nov 20, 2010 at 7:49 PM
    Reaper10
    Brandon
    Experts come in all forms. I figure if you have a question and someone comes up with an answer...bang, expert! Seriously, this is why I surf this site 90 times a day, I love it here. Costs me a ton of money but I still love it!
  9. Nov 20, 2010 at 7:50 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    spray a little wd40 on the threads before attempting to adjust them. should help out some
  10. Nov 20, 2010 at 8:05 PM
    Reaper10
    Brandon
    Great idea, thanks. Hey I'm open to whatever suggestions you guys got.
  11. Nov 20, 2010 at 8:05 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    x 100 good call.
  12. Nov 20, 2010 at 8:06 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    i know what your saying.its (tw) is/was very spendy on my pocket.lol
  13. Nov 21, 2010 at 10:18 AM
    Reaper10
    Brandon
    Thanks for the help guys, I finished off the adjustments this morning and let me tell ya, those things are a bear to adjust. After driving around for a bit it looks like I got the drivers side to within a quarter inch of the passenger side. I'm thinking good enough! Sitting in the waiting room of the alignment place right now. Now all I have to do is replace the sway bar link I managed to tear yesterday. Oops. Oh well, everytime I tear into the truck I learn something new. Thanks again guys!
  14. Nov 21, 2010 at 10:24 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    hmmm,my foxs are real easy to adjust on the truck.i would of tried to get them even.a 1/4" is a 1/4" ya no.good luck.
  15. Nov 21, 2010 at 10:49 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    When I had the Toytec's on my truck they were a pain to adjust. It eventually came to the point where I had to compress the spring to spin the collar. I'm glad you were able to adjust it while they were still on the truck. :thumbsup:
    Pictures of the finished product? :D
  16. Nov 21, 2010 at 10:51 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    didnt know they were that bad to adjust.
  17. Nov 21, 2010 at 10:54 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Maybe not all, but mine might have gotten mud in there from wheeling which could have made it difficult to adjust.
  18. Nov 21, 2010 at 10:56 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    i see.well maybe the op has mud to or they are just a pita.
  19. Nov 21, 2010 at 1:03 PM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    I've adjusted mine a couple of times; I recently had the left side sag causing horrendous tire wear. Anyway, I found Break Free w/ teflon much, much better than WD40 to make the adjuster easier to turn. Use compressed air to blast off dirt etc before spraying lube on them. Make sure the spanner wrench is as close to perpendicular to the shock body, they are flimsy and pretty easy to bend. Take a very detailed measurement from fender to axle centers right when you get the alignment done, so it's easy to re-adjust if (when) the springs sag. Mine sagged quite a bit right after installation, and as I said the left sagged quite some time later. Since there's no lock on the adjuster, I wonder if it's possible the adjuster turned out with road vibration etc.? It was a good 1/2" lower than the right side.
  20. Nov 21, 2010 at 1:25 PM
    Reaper10
    Brandon
    No dirt or mud yet, they went in brand new yesterday. They're not impossible to turn just requires a good amount off ass behind the wrench. The first try with the alignment didn't go well and I'm having them redo it right now. I took some pics while I was installing and I'll toss one up here shortly. These alignment guys are killing me...what's so hard to understand about 0 camber and 0 toe? Hey alignment guys, if my tire chirps when I drive, the toe ain't 0!!! Maybe the second time will go better.
