Toytec Coilover Lift Tolerance
Discussion in 'Suspension' started by JCool, May 21, 2013.
  1. May 21, 2013 at 4:07 PM
    JCool
    JCool [OP] Member
    Colorado Springs
    '13 Tacoma TRD Off-Road
    3" Toytec Coilover Lift Kit 285/75-16 BFG A/Ts 16x9 XD Series Addicts
    Hey all! I hate that my inaugural post is a simple question (for those who know), but here goes:
    I just had a Toytec coilover lift w/AAL installed (I have one good arm right now, ruptured biceps tendon...boo!) on my new '13 Tacoma TRD Off-Road and noticed each wheel well lip is sitting at a different height from hub center. My LR is 1/2" lower than the RR (seems legit). My LF, however, is sitting 3/4" lower than the RF. Is that too much of a delta?
    I understand the the gas tank, engine bay components, etc, cause differences for each corner. I'm also getting new tires and wheels this week, warranting an alignment, but if I need to have them adjusted then, I can...just don't want to jump the gun. It's only got 140 miles on it, and is still settling...I'm sure.
    Input greatly appreciated. Nice to be a part of TW!
  2. May 21, 2013 at 4:18 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Did you put the lean spacer on the driver's side? Tacomas are known to lean so when installing aftermarket coils, you either need to crank up the driver's side a bit more or install a lean spacer above the coil.
  3. May 21, 2013 at 4:20 PM
    JCool
    JCool [OP] Member
    Colorado Springs
    Nope...not on there. How many miles should I put on it before cranking it up? If I need to wait for a bit, I should be able to do it myself. BTW, both are adjusted to the 9th thread (from the bottom).
  4. May 21, 2013 at 4:21 PM
    Pugga
    Massachusetts
    If they have an adjustable collar, do it before you get an alignment.
  5. May 21, 2013 at 4:24 PM
    JCool
    JCool [OP] Member
    Colorado Springs
    They do...got the wrenches in the truck now. Will get it done when the wheels are off.
