toytec coilovers left vs right
Discussion in 'Suspension' started by nurseboy, May 14, 2009.
  1. May 14, 2009 at 2:10 PM
    nurseboy
    nurseboy [OP] Well-Known Member
    Jan
    Riverside, Ca
    I remembering browsing around and seeing someone post that there is a difference between the left and right front coil over for this kit and I can't seem to find it. Can someone elaborate on this and give me the info? Also does it for the same on the rears for the Bilstein 5100 rear nitrogen gas shocks? Is there a specific left vs right shock?
    And one other question. This kit comes with TT-RS - rear axle degree shims for proper pinion angle alignment (Not pictured...on the How-tow for installing an add-a-leaf, this part wasn't used? Is this necessary or just an added improvement? And where do I use this?
  2. May 14, 2009 at 2:49 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    the fronts are different due to the added weight from you, gas tank, and battery. As far as telling them apart....im not sure. But the backs do not matter which side.
  3. May 14, 2009 at 2:55 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    really..... hmmmm..... well i hope i have good luck haha
  4. May 14, 2009 at 2:57 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    and by the way the shim goes on the bottom of the leaf pack against the axel
  5. May 14, 2009 at 2:58 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    U may or may not need the shims - i started w/o them, then got vibe's. Installed the shims, and it cut down the vibes a little
  6. May 14, 2009 at 2:59 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    fat side towards the rear of the truck
    from google:
  7. May 14, 2009 at 3:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Only the OEM springs are side specific. The Toytec coilovers are not.
  8. May 14, 2009 at 4:20 PM
    nurseboy
    Jan
    Riverside, Ca
    if this is the case would I have to adjust the left coilover a little higher then the right?
  9. May 14, 2009 at 4:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    yes. Just a little bit, like 1/8th inch or so.
  10. May 14, 2009 at 6:24 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    ahhhh gotcha.
