toytec coilovers/LR UCA's/CV angles/ pics of some flex
Discussion in 'Suspension' started by 907taco, Oct 17, 2010.
  1. Oct 17, 2010 at 7:46 PM
    907taco
    907taco [OP] Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    finally got around to installing my coilovers/LR UCA's from toytec> no pics of install as it was a last minute decision at work using someone else's tools and i did not have my camera. I did this by myself and it took about 6 hrs. It has settled a tiny bit > due to me romping on some trails trying to make it settle. on to pics.
  2. Oct 18, 2010 at 1:52 PM
    DaWillDaBeast
    DaWillDaBeast Well-Known Member
    Will
    Colorado
    05 Tacoma 4x4 with some goodies
    Things
    Looks great man :thumbsup:
  3. Oct 18, 2010 at 2:27 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    say goodbye to your cv's in 8k miles.
  4. Oct 18, 2010 at 2:44 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    x2
    Get a front diff drop!
  5. Oct 18, 2010 at 3:11 PM
    Bsly862
    Bsly862 Well-Known Member
    Nate
    Denver, CO
    08 Off Road
    3in lift
    x3
    I would look at lowering the front some
  6. Oct 18, 2010 at 8:17 PM
    907taco
    Bobby
    Alaska
    front dif drop is in, coilovers are set that way from toytec. Are my cv angle too out of whack?
  7. Oct 18, 2010 at 8:19 PM
    907taco
    Bobby
    Alaska
    alright maybe i should now that you guys have said something, i thought it was good to go as they came pre set from toytec.........
  8. Oct 18, 2010 at 8:49 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    looks great man except those cv angles
    did you measure your lift in the front?
    I have 23 1/4" from centre of hub to bottom of fenders, whats yours?
    I just put SAW coil overs in the front, I set it to about 3" lift in the front and my CV angles don't look bad at all compared to yours.
  9. Oct 18, 2010 at 8:52 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    fyi diff drop doesnt do much if anything
  10. Oct 18, 2010 at 8:57 PM
    907taco
    Bobby
    Alaska
    i will measure tomorrow, i didn't measure when i installed as i was pressed for time to get it to the alignment shop after i installed. i am sure they are over 3" and i thought they would have settled down a bit, i guess i should hold off on the wheeling till i get this resovled.
    so your set at 3" with what size tires, i am rolling on 265 75 16's, so i am guessing my measurment should be the same as yours right?
  11. Oct 18, 2010 at 9:00 PM
    snorola
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    tire size won't affect the measurement from centre of hub to bottom of fender thats what it is better than measuring from the ground.
    stock is around 20" in the front I believe so you should be around 23" for a 3" lift.
  12. Oct 18, 2010 at 9:06 PM
    907taco
    Bobby
    Alaska
    thanks for your replys, i feel better now that someone that knows more than me chimed in...........thanks again.....
    one last question, am i going to need another alignment for lowering it down to about 3"?
  13. Oct 19, 2010 at 3:40 PM
    907taco
    Bobby
    Alaska
    measured at 24" from center of hub to bottom of fender, getting it fixed tomorrow.....
  14. Oct 19, 2010 at 5:41 PM
    Bsly862
    Nate
    Denver, CO
    08 Off Road
    3in lift
    technically since you changed the geometry of your suspension you should get an alignment after it is lowered
  15. Oct 19, 2010 at 6:30 PM
    ccextra1976
    ccextra1976 Well-Known Member
    Utah
    2011 timberland mica DC 4x4 off road
    newb question here, but if you removed the factory clamps and slide the ends of the boots toward each other (maybe an inch) wouldn't it separate the bellows in the boots a little and relieve the rubbing? Or would the suspension flex/turning radius tear the boot?
  16. Oct 19, 2010 at 6:34 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    my cv's look like that, and i abuse the hell out of my truck and my cv's are fine..
  17. Oct 19, 2010 at 6:36 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    ummm I gotta measure mine, i just put some Toytec adjustable.
  18. Oct 20, 2010 at 7:21 PM
    907taco
    Bobby
    Alaska
    i am retracting what i said "that it came that way from toytec" i raised to level the truck even, my shocks are over extended and way out of alignment, i have been driving over a week on them, my almost new tires are jacked due to having major out wear on my tires, totally pissed right now because i just had studs put in them, now i need new tires....................
  19. Oct 22, 2010 at 1:03 PM
    907taco
    Bobby
    Alaska
    alright, not that i am at 22 3/4 in. middle of hub to bottom of fender, my uca's are right where they need to be....properly aligned and what a difference it makes. I should have left the coilovers set at from the factory but instead i raised to level the truck which made it 24" in the front. my alignment was way off and instead of getting full potential of shocks working properly "it was on its tippy toes" and extended, (what a stiff freaking ride that was, and i was getting Heavy outwear on my tires) vibrations from hell, now that i dropped it back to where i should be no vibrations at all !!!!! <with proper alignment.
    I will post pics of cv angles when i get home and you can see the difference.
  20. Oct 23, 2010 at 3:16 PM
    Bsly862
    Nate
    Denver, CO
    08 Off Road
    3in lift
