Toytec corrosion protection !!
Discussion in 'Product Reviews' started by Yota_Fox, Dec 1, 2012.
  1. Dec 1, 2012 at 9:43 AM
    Yota_Fox
    Yota_Fox [OP] Active Member
    Ben
    Beaverlodge,Alberta, Canada
    08 DCLB TRD Ducks Unlimited
    Grillcraft , Piaa behind grill and fog in bumper,BHLM, Kenwood DD In Dash Nav, Garmin My Mechanic on Nuvi1495, Max 4 Duck blind seat covers, Debadged , cargo bed lights, Wilson cell booster,
    Ok finally got the weekend to start this install my question is has anyone put or used some thin plastic or anything to keep from corrosion between the top coil aluminum and the frame mount to keep things from corroding aluminum and steel don't mix we'll and noticed after pulling out my revtec that the top alum plate is corroded so to keep from doing the same to these pretty toytecs :) can I put like 3m or something like it as coating to keep this from happening again ?!? Something real thin obviously not to after the lift
  2. Dec 1, 2012 at 9:54 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Aluminum paint
  3. Dec 1, 2012 at 9:56 AM
    Yota_Fox
    Ben
    I don't have time to let that dry lol Jk true true what about a couple layers of window tint
  4. Dec 1, 2012 at 9:59 AM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    dont use something that will hold moisture if your going with something household..
  5. Dec 1, 2012 at 10:00 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Fluid Film
  6. Dec 1, 2012 at 10:07 AM
    Yota_Fox
    Ben
    Good point about the moisture
    Thanks I'm thinking the window tint should work maybe only one layer cut out and stuck on just something to keep from direct alum to steel contact
  7. Dec 1, 2012 at 10:48 AM
    GotLift37
    North East AL
    07 4Runner 4WD
    that plastic tint will probably not last long
  8. Dec 1, 2012 at 11:14 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I have never heard anyone calling the Toytec spacers pretty. :)
    A coat of lithium grease on the top surface of the spacer will last a long time and displace any moisture. Just be sure to wipe off any excess from three studs after you have seated the strut in place.
  9. Dec 1, 2012 at 11:44 AM
    Yota_Fox
    Ben
    Ya pretty isn't quite the word lol grease will do just fine
