Toytec drivers side lean spacer help
Discussion in 'Suspension' started by esimmons, Jan 2, 2012.
  1. Jan 2, 2012 at 7:44 AM
    esimmons
    esimmons [OP] Well-Known Member
    Evan
    Kannapolis, NC
    2007 PreRunner
    Nerf Bars, Bull Bar
    Ok so I got and have successfully install 5100's and a 2inch aal. As soon as I got finished I realized that I for got to put on the drivers side lean spacer . I really want to put it on , but at the same time that is a ton of work for a half inch. I have 1 concern about doing it and I would appreciate your input. I am worried that it will make my ride worse like when installing blocks. if it does make things stiffer I deffinately do not want to do it but I have to decide fast bc tomorrow is my only chance to do it. Thanks in advance!
  2. Jan 2, 2012 at 7:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It wont affect the ride. It goes on the top of the assembly, not in the spring.
  3. Jan 2, 2012 at 7:46 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    The toytec taco lean spacer is a top plate spacer, which does not affect ride quality, as it is installed outside of the coilover assembly.
    Edit: gahhh!
  4. Jan 2, 2012 at 9:54 AM
    esimmons
    Evan
    Kannapolis, NC
    2007 PreRunner
    Nerf Bars, Bull Bar
    Thanks Guys!
