Toytec / Eibach silver 620lbs springs.
Discussion in 'Suspension' started by eight3one_offroad, Mar 18, 2010.
  1. Mar 18, 2010 at 10:23 PM
    eight3one_offroad
    eight3one_offroad [OP] Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    Hey everyone,
    I just got my Toytec / Eibach silver 620lbs springs from UPS, I will put them on tomorrow morning. Is there a right way to put these things in? I mean the smaller wound part goes on the bottom and the bigger opening to fit with the top correct? I just want to make sure I'm doing it correctly. Thanks for any advise.
    - Rich
  2. Mar 18, 2010 at 10:49 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    top is flat. bottom ends at a point. i have the same set up. .85 on the 5100s is a little lower in the front. i also have a 2" non tsb aal
  3. Mar 18, 2010 at 10:51 PM
    eight3one_offroad
    Richard
    Thanks dude, so the bottom part is when it wounds up from big to smaller... the spring that is I'll get pics tomorrow of it installed
    - Rich
  4. Mar 18, 2010 at 10:54 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    the top is flat on top. the bottom fits into the coil plate. there is a groove where the coil fits into. check my build pics
  5. Mar 18, 2010 at 11:02 PM
    eight3one_offroad
    Richard
    Okay I see what you mean now... yeah it does angle at the bottom to fit into that plate, how much lift did you achieve with the 5100s set to .85?
    - Rich
