Toytec Front Top Spacer Sitting High
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AKMT, Nov 30, 2019.
  1. Nov 30, 2019 at 8:06 AM
    AKMT
    AKMT [OP] Member
    Morning everyone. I recently installed the Toytec Top 1 Front Spacer Kit on my 2019 Tacoma DCLB. It has been about a week since installation and the front end is still sitting almost 1 inch about the back. This is based on measuring from hub center to the fender flare. I am wondering if anyone has encountered this problem or has any insight into what might be causing it. My understanding is that the original rake is about 1 inch, so these spacers (advertised to lift the front end 1/2 to 3/4 of an inch) should only make it level or even a little less. Any advise or help is appreciated.
  2. Nov 30, 2019 at 8:17 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Post a couple pics of your install.
    There isn’t a general rule for what the different in front and rear height is, the only way to know what your truck needs to leveled is to get a tape measure, compare front to rear heights and find the difference.
    71tattooguy likes this.
  3. Nov 30, 2019 at 12:57 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    1” spacer will lift front 2”. So you probably want a 1” block in back. Post pics
  4. Nov 30, 2019 at 1:21 PM
    AKMT
    AKMT [OP] Member
    I have a 1/4" spacer on the driver side to correct the lean as well.
    63UUNd5xr4UHP7F3XmOIVi73nLCksx9-bEr87Qt7_bf83405f23774d3c2c19105d24762b6291ab4d3e.jpg
  5. Nov 30, 2019 at 1:34 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I that pic the front doesn’t look high.
  6. Nov 30, 2019 at 1:34 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Looks fine
