Toytec Install tomorrow...Last minute Q's
Discussion in 'Suspension' started by Squaretail, Feb 3, 2012.
  1. Feb 3, 2012 at 4:31 AM
    Squaretail
    Squaretail [OP] Well-Known Member
    New Hampshire
    08 V6 Black Blurr
    So I called Toytec to ask what the coilovers were set at. Jeff said 0.85, which gives me the full 3in. So now I'm a little confused because I thought the adjustment options were 0.85, 1.5, 2.5, and 3" or something like that???
    Can someone help me clarify this (the 5100 shocks are not the fully adjustable ones)... Also, do you think I need to install the rear axle degree shims?.... Seems like no big deal, but I dont want any vibrations later down the road.
    Toytec advised I install the front diff. drop. What do you guys think?
  2. Feb 3, 2012 at 4:58 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    Assuming you are getting 5100s and Eibach coils. The 5100s are fully adjustable, but since the Eibach coils are already stiffer and taller than the stock coils, setting the 5100s at .85 will provide just shy of 3".
    I dont know what you're doing for your rear suspension, but don't bother with axle shims until you have a vibration problem. Same goes for the diff drop. Wait and see what your CV anlges will be at, after the front suspenion settles in a bit.
  3. Feb 3, 2012 at 5:30 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I think you left out some information. What kit did you buy from Toytec? They make 2 kits with the 5100's and Eibachs. One will put you right at 3", the other one a little under. Could you put up a link to the kit you actually purchased?
    I'd leave the differential drop out, it doesn't actually 'drop' the differential, it rotates it. You can always go back and install it later if you feel you need it.
    What are you doing for a rear lift? Unless you're going over 2" of lift for the rear, you shouldn't need shims.
  4. Feb 3, 2012 at 6:49 AM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    x2 ^...u must of gotten the coilovers....which are preset to a 3" gain...85 on billies + Eibach coils + toytec's billet top plate spacer= 3"
    the only other way is their other kit which I believe is 630.00 comes with coils and 5100's and u can buy the tp15 top plate spacers which would give u the full 3"'s
    the main difference is the regular top plate spacer vs a new billet one...you also get axle shims with the coilover kit which is around 899.00
  5. Feb 3, 2012 at 1:07 PM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
  6. Feb 3, 2012 at 1:24 PM
    Pugga
    Massachusetts
    Do you have the TSB rear leaf pack? (Count the # of leafs, 3 + overload = TSB leaf pack, 2 + Overload = non-TSB leaf pack). If you have the TSB leaf pack plus the 2" AAL, you're probably pretty close to where shims wouldn't be a bad idea although not a requirement. Non-TSB pack + 2" AAL you could honestly go either way but would probably be fine without them. I'm running 2" of lift on a TSB leaf pack and do not have shims on mine.
    As far as your first question... the 5100's have 4 settings; 0, .85, 1.75 and 2.5" of lift when used with STOCK coils. The set-up you purchased comes preassembled with a taller, stiffer lift coil. The 5100's will be pre-set to .85 and come with a thicker top plate so you'll sit at 3" of lift once installed.
    Side note, I hope you have aftermarket UCA's for alignment purposes.
  7. Feb 3, 2012 at 1:44 PM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    No UCA's yet.... hoping it won't be huge deal.
    I have the non-TSB leaf pack.
    Is there a left and right to coilovers and rear shocks with the lift kit.
  8. Feb 3, 2012 at 1:52 PM
    keisersoze
    keisersoze Active Member
    squaretail would it be possible for you to post pics when you are done. I would like to see it installed as I am thinking about getting the same kit
  9. Feb 3, 2012 at 1:59 PM
    Pugga
    Massachusetts
    Your alignment might be a little jacked but drive for a bit and see. I think you should at least plan for them, you're probably going to want them sooner rather than later.
    The OEM are side specific, the Toytec ones are not but you have to use the top plate on the driver's side to offset the Taco lean. Rear shocks are not side specific.
  10. Feb 3, 2012 at 2:04 PM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    My coilovers are already assembled, so what top plate are you referring to?
    Do I need to order an additional spacer to account for the drivers side lean?
    If so, that means I need to disassemble my coilovers to put the spacer on, correct? It doesn't seem worth it now, if its only for aesthetics
    Also, what should I torque my coilovers to?
    What should I torque my sway bars to, since I also have to remove them?
    Thanks guys!
  11. Feb 3, 2012 at 4:46 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Yes your coilovers are assembled alreadyand the "billet top plate spacer" is already in place..your set up comes preset to the .85 setting so if you dont want 3"'s you will need to set the coilover (5100) to the 0 setting and you will probably get between 2.25 and 2.5' of lift...that system only has 2 settings so make sure u adjust before install..this is a different set-up from the adjustable wrench type...hope this helps
  12. Feb 3, 2012 at 6:15 PM
    Pugga
    Massachusetts
    The 1/4" top plate spacer just sits on top of the coil assembly, no need to disassemble the coils to put it in. I don't remember the torque specs, but you could give a quick search through the 2nd Gen DIY or Mods and Tutorials section. I used the thread 'BJ Moose Installs a Full OME Kit' for reference. (search for member BJMoose, and look at the threads he has created)
    http://www.tacomaworld.com/forum/su...talls-full-ome-kit-rear-brake-lines-pics.html
    The set the OP ordered is preassembled. He'd need a spring compressor to get them apart to set them back down to 0.
