Toytec lift coils
Discussion in 'Suspension' started by Overheadspec, May 11, 2009.
  1. May 11, 2009 at 9:10 AM
    Overheadspec
    Overheadspec [OP] Member
    Houston, TX
    08 Prerunner Longbed
    I have a few questions: Is it ok to just get the toytec lift coils put on the front to raise prerunner 2"? Also, are the stock shocks (not bilsteins) ok to use, or are they not long enough? Lastly, is raising the front just 2" enough to need UCA's or will it be somewhat acceptable without replacing? Thanks for responses.
  2. May 11, 2009 at 9:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can use them with the stock shocks, but it wont ride good. The OME springs are best used with the OME shocks. You can lift 2" without the use of aftermarket UCA's, but the alignment will be off.
