Toytec Lift Help
Discussion in 'Suspension' started by rhion82, Nov 21, 2010.
  1. Nov 21, 2010 at 9:23 AM
    rhion82
    rhion82 [OP] El Duderino
    Mitchell
    TN/GA
    16 Taco
  2. Nov 21, 2010 at 9:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The 885's would give 3" lift, without the use of the spacers. You should also consider replacing the shocks.
  3. Nov 21, 2010 at 9:38 AM
    rhion82
    Mitchell
    TN/GA
    16 Taco
    If I order the 885 and not the shocks would it hurt the truck any? I will prob buy the shocks sometime next year.
  4. Nov 21, 2010 at 9:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The stock shocks are not designed to dampen the higher spring rate of the 885 coils. The ride wont be as good.
  5. Nov 21, 2010 at 9:46 AM
    rhion82
    Mitchell
    TN/GA
    16 Taco
    Would buying TRD shocks take care of it or would I have to get the 5100's?
  6. Nov 21, 2010 at 9:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Either the 5100's, or the Old Man Emu shocks. I would get the 5100's over the OME 90000's
  7. Nov 21, 2010 at 10:34 AM
    rhion82
    Mitchell
    TN/GA
    16 Taco
    Geez thats gonna jack up the price quite a bit. Might have to put off buying the shocks. Can't afford putting new shocks on all four corners cause I'm a poor college kid!
