Toytec lift in Austin
Discussion in 'Texas' started by superman2481, Apr 26, 2012.
  1. Apr 26, 2012 at 9:41 PM
    superman2481
    superman2481 [OP] Well-Known Member
    Possibly ordering the 3" spacer lift and aal with ome coil and was wondering if any Austin members would be willing to help me install?? Last time I owned a tacoma I had fellow TTORA members help install "cornfed suspension" spacer and aal haha.. I live in an apt so id pretty much supply pizza and beverages aslong as we drank after my lift was on lol let me know,thanks and I look forward to meeting y'all soon...
  2. Apr 26, 2012 at 9:44 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    your ordering a spacer lift WITH a OME coil? Its either or. Id stick with the OME coil
  3. Apr 26, 2012 at 11:31 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Which lift is it exactly you have a link? If you were closer I would help too.
  4. Apr 27, 2012 at 4:32 AM
    superman2481
    Here's the link..
  5. Apr 27, 2012 at 4:34 AM
    superman2481
    Or should u go with this option and use the money for diff shocks?
  6. Apr 27, 2012 at 4:39 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    This is the better of the two. Spacers are a no go....
  7. Apr 27, 2012 at 4:49 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    I would not recommend either lift for you. In the long run, it will be bad on your stock suspension and limit travel. It will also stress your coil overs a bit using that spacer. I had one and once I removed and replaced it with a aftermarket coil over, you will notice a huge difference in handling and smoothness.
    Don't know what your spending limit is but here some to help:
    Get the OEM lift. It will be worth every penny.
    Here is a cheaper 3 inch lift I've seen some people have good thoughts about.
    http://www.4wheelparts.com/Lift-Kit...c=1&t_s=38&t_pt=3533&t_pl=1808&t_pn=EXPK5081B
  8. Apr 27, 2012 at 5:11 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    Fixed it for ya. The OME lift is nice thats what im running. I'd stay away from the procomp lifts as from what ive heard the ride will be pretty stiff.
  9. Apr 27, 2012 at 5:49 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    I wasn't sure if he is going to wheel or not. other wise ya your right
  10. Apr 27, 2012 at 6:00 AM
    Nubes
    Nubes Toyota Addict
    Texas
    2023 Red T4R ORP
    This ^^^ ;)
    lol but whatever you choose to do I'm willing to come out and try and help. But I am still new at suspension stuff and want to learn more :rolleyes:
  11. Apr 27, 2012 at 6:05 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    we all start somewhere, I was in the same position a year ago with a stock truck. now look at what happened to it :cool:
  12. Apr 27, 2012 at 2:48 PM
    BulletToothTony
    OP you could also go the billy 5100 route depending on your budget...
  13. Apr 27, 2012 at 5:53 PM
    superman2481
    Thanks for all the suggestions, and it's a prerunner but I'm not gonna do too much wheeling, mostly for looks and mild offroad capability
