ToyTec Lift Installed - Now Questions...
Discussion in 'Suspension' started by DblD, Nov 21, 2009.
  1. Nov 21, 2009 at 10:26 AM
    DblD
    DblD [OP] Well-Known Member
    Dave
    SW Missouri
    '18 DCSB TRD/OR - Prem. & Tech.
    I just installed a ToyTec Lift (Option 4 and Option 5 for those that were in on the group buy) It is Bilstein 5100 front and rear shocks, Eibach Coils, Add A Leaf in the rear, and Light Racing UCAs. These are the numbers I’m measuring. Could this be right? What have I done wrong? Just got back from the alignment shop and everything aligned fine and it drives great.
    Pre Install Measurement Front:
    Post Install Measurement Front:
    Pre Install Measurement Rear:
    Post Install Measurement Rear:
    The rear measurements seem right in line with what I expected. The front – no so much!
    Here’s how it sits.
    Pre:
    Post:
    Any ideas?
    Thanks,
    dd
  2. Nov 21, 2009 at 11:58 AM
    DblD
    Dave
    SW Missouri
    CRAP!!!
    Just realized after reading a few more posts that I put the clip in the wrong groove. I put it in the upper most groove on the shock and I guess it should be in the 2nd from the bottom. The paperwork that came with the socks was marked:
    Something
    2.5
    I looked at the shock instructions and thought “2.5in. lift… that’s what I want” So I put the clips at the 2.5 position.
    What am I going to ruin if I drive one week (about 190 miles) until I can take everything back apart? Or should I park it until I have another day off?
    dd
  3. Nov 21, 2009 at 2:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be ok for a week. BUT, you may be doing some damage to the ball joints.
  4. Nov 21, 2009 at 2:40 PM
    DblD
    Dave
    SW Missouri
    Thanks Chris4x4
    Just the info I was needing. Kicking myself in the ass for having to do this twice. Will I need another alignment after the reinstall?
    dd:frusty::frusty:
  5. Nov 21, 2009 at 2:46 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    yup :)
  6. Nov 21, 2009 at 2:54 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Make sure the collars on the bottom of the spring are not upside down as well. They should slip down over the lock ring and keep it in it's home.
    My Eibach 1.6 springs are at .85 notch and it rides great.
    36 1/4" from the ground with 265-65-17 tires.
    2" AAL in back 39"from ground.
    I am suprised they could align it. With a 1/4" spacer on top of the LF my alignment guy said I was almost maxed on that side.
  7. Nov 21, 2009 at 3:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It will be at the max. of the alignment, but still "In spec". To get it perfect, you will need different UCA's.
  8. Nov 22, 2009 at 9:26 PM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    This is also what I thought when I saw the picture.
  9. Nov 28, 2009 at 7:47 PM
    DblD
    Dave
    SW Missouri
    Ok…
    This is better. It took doing it twice to get it right. The spring perches on the shocks have been changed to the .85 setting. Out the $$$ for another alignment but I figure it’s worth it to know that it is done correctly this time around.
    Thanks to all who posted up.
    dd
    Here’s how it sits now.
  10. Nov 28, 2009 at 7:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear you got it! :)
  11. Nov 29, 2009 at 5:08 AM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    nice she looks good!
