Toytec lift kit and Fox or Bilstein shocks
Discussion in 'Suspension' started by eppy, May 20, 2012.
  1. May 20, 2012 at 6:36 AM
    eppy
    eppy [OP] Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Hey,
    Looking to get some input to see what type of lift kit and shocks will suit my Taco best. Decided to go with a 2.5" lift and was considering Fox or Bilstein shocks. Any input would be appreciated. Also a nice skid plate!!!
  2. May 20, 2012 at 7:31 AM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    If you look around the forums you will see alot of info pertaining to both these setups. Billsteins= entry levelish(above spavers atleast) lift with decent offroad capabiltiy. FOX=way more cash......and def better offroad capabilty. If you plan on going a little nuts.....sounds like you are if you want a skid plate then spend and get the fox. Especially if you intend to go fast over shit off road. Billsteins for a nice lift that can handle offroading at a slower speed.
    Also......you can custom valve the fox i believe for any application.
    BUDGET?
  3. May 20, 2012 at 7:47 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Welcome to TW! Since this forum is for introductions only, recommend you spend some time in the 2nd Gen. Tacomas and Suspension forums. Both contain a wealth of information about your truck and it suspension.
  4. May 21, 2012 at 6:30 AM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Thanks guys appreciate the info. See a lot of people going with Toytec 3" spacer lift kit and was wondering if anybody is familar with the build and any considerations. Also, see there aren't that many Fox Venders and the only one found was in Texas. Therefore, any recommends on something comparable to Fox as far as Coilovers and shocks. Ton of info to sort through and just trying to decipher what the best option would be. Budget is around 3 grand give or take a few hundred, for lift and shocks minus installation. Also, my Taco is a manuel and wondering if anybody has installed the TRD short shifter and was a worth the Cash!!
  5. May 21, 2012 at 6:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If your budget is $3k, don't even consider the spacer lifts. Check out Downsouth Motorsports for Fox or Icon stuff. They have great customer service.
    For a short throw shifter, check out URD (Underdog Racing Development). He might be in your neck of the woods (Huntington, MD is their HQ) and they sell great aftermarket performance goodies for your Tacoma.
  6. May 21, 2012 at 6:50 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    also for an adjustable coilover, there is no "lift and shocks". the front coilovers from fox, king, icon, etc are all adjustable and will provide the lift for the front. the rear you'll need compatable shocks and either an AAL or new leaf pack. four your budget, you can definitely get a good quality setup of COs, rear shocks, and a leaf pack. like others said, stay away from spacers and blocks.
  7. May 22, 2012 at 10:48 AM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Thnx guys,
    Appreciate all the info and will give URD & Downsouth Motorsports a shout. Nice to know that URD is in my backyard because I need to research a few upgrades for my 6 speed manual. Will begin to post pics as the old Taco build gets on it's way.
