toytec lift kitsss, which one to get?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by loves.her.truck, Mar 2, 2011.
  1. Mar 2, 2011 at 10:56 AM
    loves.her.truck
    loves.her.truck [OP] Well-Known Member
    Blu
    San Diego
    06 Prerunner trd
    Hello boys! :D
    i've been doing countless hours of research on this subject and everytime i've made up my mind about what lift kit to get, something else comes up that confuses me all over again.
    i own a 06 prerunner TRD and i'd like to give it at least a 2.5-3 inch lift. mainly for looks but, the occasional off-roading will take place-nothing too crazy.
    i'm really interested in the lift kits that toytec has to offer, especially the ones with the bilstein shocks.
    can anyone point me in the right direction of which kit would benefit me the most?
    for example, i don't understand why one kit is a little over $1000 and the other one is around $650. . what's the difference?
    oh, not to mention i'd like to get bigger tires but, which ones should i get without having to do any "trimming".
    thank you!
    my baby <3
  2. Mar 2, 2011 at 12:05 PM
    Mtnbker343
    Mtnbker343 Well-Known Member
    Binghamton, NY
    2016 TRD Sport
    18" XD Monster wheels with a 4.5" backspace and a set of P285/60/18 Nitto Terra Grappler tires....Toyteclifts 3in coil and add a leaf. Window tint. tonneau cover.... more to come!!!!!
    New 18" XD Monster wheels with a 4.5" backspace and a set of P285/60/18 Nitto Terra Grappler tires....Toyteclifts 3in coil and add a leaf. totally happu with my $299.99 Coil,spacer and add a leaf from toytec. truck looks great and ride smoother then stock...
  3. Mar 2, 2011 at 12:10 PM
    Xshark
    Xshark Well-Known Member
    Michael
    Rogers, AR
    08 Taco
    Icon progressive leaf, 3-leaf pack. Bilstein 5100's on all corners, front set at 2.5" Spidertrax wheel spacers Satoshi Grille Mod
    The most popular method of lifting (from my view) on this forum is to have the rear TSB done, or add-a-leaf (AAL) to the rear spring. That will give you 1.75" or so lift. Then install Bilstein 5100 shocks on the front and either set them at 1.75" for a slightly raked truck, or 2.5" for a mostly level truck.
    TSB is free if you can convince Toyota you need it, and your truck is still under warranty. Otherwise, AAL will cost about $70 (not installed). Front billies run about $100 each. Installation of all this varies shop to shop. (I've seen $350 to $900 on this site.)
    You will then be able to go with a larger size tire, but you still may need to trim the mud flaps. It depends on what size you want to go with.
    A popular 16" tire that most people use is 265/75.
    A popular 17" tire that most people is is 265/70.
    Even those sized may require some trimming, but any larger and you will probably need to remove your mud flaps.
    Don't forget to check out the wheels/tires topic.
    http://www.tacomaworld.com/forum/wheels-tires/
  4. Mar 2, 2011 at 12:23 PM
    trd sport
    trd sport Well-Known Member
    queens,ny
    07 double cab trd sport
    Hey Mtnbkr, did you get the eibach springs or the toytec adjustable coil?
  5. Mar 2, 2011 at 12:50 PM
    lopezoscar03
    lopezoscar03 Well-Known Member
    lopezoscar03@gmail.com
    i have read this before about convincing toyota for some parts. how would one go about doing this?
  6. Mar 2, 2011 at 12:57 PM
    ARC
    ARC Well-Known Member
    Andrew
    Grand Junction, CO
    '11, TRD 4X4, 6SPD
    If you don't need the TSB you don't need the TSB. You would know what the issue was if you needed it
  7. Mar 2, 2011 at 2:11 PM
    toyohtadude
    toyohtadude Well-Known Member
    Eric
    Austin, TX
    2017 4x4 Tundra SR5 CrewMax
    Bone stock
    I took the printed TSB in and complained about the ride with a half load (my motorcycle) in the bed. They ordered the new leaf packs and installed them the next week. No arguments at all. This was Bill Dube Toyota in Dover, NH.
  8. Mar 2, 2011 at 2:14 PM
    loves.her.truck
    Blu
    San Diego
    06 Prerunner trd
    gosh, so much info! thanks guys :) i'm still a little iffy about what to get.
    some peeps are even trying to convince me not to do it because it might not be a good idea.
    would any of you guys know what can go wrong if i get a lift on my truck?
    long run?
    short run?
  9. Mar 2, 2011 at 2:15 PM
    loves.her.truck
    Blu
    San Diego
    06 Prerunner trd
    brilliant! :)
  10. Mar 2, 2011 at 2:24 PM
    toyohtadude
    Eric
    Austin, TX
    Bone stock
    Oh, to stay on topic... ;) I am looking at the same kit as Mtnbker343 for the 3" lift. After all the reading here, it seems to be the one that offers the best bang for the buck, the best ride afterward and isn't really difficult to install. The general thought is the medium coils and be sure to get the TSB AAL if you've had the leaf packs installed. ToyTec is awesome because even swapping options to suit your needs, the price remains the same. OME3-05-AL is the $299 kit.
    Don't forget to check their thread for the latest discount code! :D
  11. Mar 2, 2011 at 2:26 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    she is a 06 so no tsb for her.
    must be within 3 years or 36k miles
  12. Mar 2, 2011 at 2:35 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
  13. Mar 2, 2011 at 2:37 PM
    toyohtadude
    Eric
    Austin, TX
    Bone stock
    Understood, but she could have had it done back when she was still eligible right? ;) Or, if she got the truck used, it could have been done prior to?
  14. Mar 2, 2011 at 2:41 PM
    toyohtadude
    Eric
    Austin, TX
    Bone stock
  15. Mar 2, 2011 at 5:44 PM
    loves.her.truck
    Blu
    San Diego
    06 Prerunner trd
    that´s exactly the one i want! but i´m not sure, if it´s the way to go. but, if it is, do i need to install anything else? i.e. change the standard options it comes with?
    grrr, lol, too much stuff to know!
  16. Mar 2, 2011 at 5:47 PM
    loves.her.truck
    Blu
    San Diego
    06 Prerunner trd
    uh, done what exactly?
    all, i know is that i rescued this truck from being taken back to the dealer :) and everything is stock on it.
  17. Mar 2, 2011 at 8:02 PM
    toyohtadude
    Eric
    Austin, TX
    Bone stock
    We were discussing the technical service bulletin (TSB) for the "Rough ride with heavy load" where they replace the rear spring packs with a 4 leaf pack that is much stiffer and actually lifts the truck 1.75" in the rear. That is what I had them replace on my truck, hence the "motorcycle in the back" comment above. ;)
  18. Mar 3, 2011 at 6:06 AM
    Xshark
    Michael
    Rogers, AR
    08 Taco
    That is an excellent kit. (so I hear). But then you might have to do more stuff.
    I found this quote while I was doing research for lifts:
    This pretty much sealed the deal for me. Sticking with Billies and AAL in the rear. I'd like to thank bjmoose for the above.
  19. Mar 3, 2011 at 6:16 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    That's the best option IMHO
    It's a great kit.
    You don't "need" UCA's for 3" lifts. It's recommended but not a necessity.
  20. Mar 3, 2011 at 6:18 AM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
