Toytec Lift Rattling My Teeth Out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SManZ, Nov 20, 2009.
  1. Nov 20, 2009 at 5:10 AM
    SManZ
    SManZ [OP] el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Hey guys,
    I installed the Toytec Ultimate Lift w/ LR UCAs two days ago and got an alignment yesterday. The rear is ok but the front is incredibly stiff. There is zero compliance on the highway and the front end shakes my teeth out. I'm reading that the Toytec springs are at 600lbs.
    Is this normal? Is this something that goes away after it settles? I have a Prerunner - is the lack of front driveline weight causing this? I drove about 250mi to my folks place last night and I'll be doing the same going back on Sunday.
    If this is normal will an ARB or similar bumper in the front soften things up?
    Thanks! And pics are coming later today if the sun pops out and lets me wash it! I got the TRD FJ rims on too! :-D
  2. Nov 20, 2009 at 5:17 AM
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    you probably have the spring tighten to tight and its not letting the suspension absorb the bumps in the road
  3. Nov 20, 2009 at 5:41 AM
    cntstan
    cntstan Well-Known Member
    Chuck
    Wisconsin now, North Carolina will always be HOME
    08 DC SR5 4X4 ; 94 Ford Bronco
    3" Toytec coilovers, rear AAL,satoshi'd grill,ARE topper,TRD exhaust, All Pro winch bumper, Warn winch, All Pro skid, Pro comp 7089's, Supersprings, Wet Okole seat covers
    I'm in the same boat but I can tell you that an all pro bumper and a winch seemed to make the ride even more jarring. I've been wondering if a different set of shocks up front would help.
  4. Nov 20, 2009 at 5:46 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    yea somethings up with your springs. Mine ride like butter
  5. Nov 20, 2009 at 9:56 AM
    SManZ
    Haymarket, VA
    Interesting...I didn't adjust them and put them on the way they were out of the box. I'll have to get some measurements between the two collars and let you know what its at. I do know that center of the hub to the fender is 24" - I measured that last night.
    Thanks for your replies!
  6. Nov 21, 2009 at 9:51 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    They do tend to soften up with some additional weight on them.
    But they should NOT be teeth rattling!
