Toytec Lift with Bilstein1500 question???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brvermilli21, Apr 21, 2020.
  1. Apr 21, 2020 at 3:05 PM
    brvermilli21
    brvermilli21 [OP] Well-Known Member
    Knoxville TN
    So I have a Toytec 3" springs installed on Bilstein 1500 (set to zero) on the front of my Taco and Icon Lift springs in the rear. Ive had the lift on for about 8 months and love it.
    After getting the lift I added a winch and C4 low pro bumper and now the front sits lower that I would like. Measuring the truck my front sits at 22" center of hub to fender and the rear sits as 24" center of hud to fender.
    My question is can I have the front Bilstein 1500's set to the first clip to get the front closer to level with the rear? I would like to have the truck level or maybe just a bit or front rake bur not 2" difference.
    Thanks
    -bv
  2. Apr 21, 2020 at 4:07 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    The Toytec springs are meant to be used on the zero setting only. May need to go to their spring with a higher load rating.
    FJ to Taco likes this.
  3. Apr 21, 2020 at 4:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    1 clip up isn't gonna hurt anything
  4. Apr 21, 2020 at 4:17 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I spoke to bilstein and Eibach in regards to this and for my specific spring (Eibach pro lift 2.5" 725lb) they stated that going to the second clip was acceptable to make up for the lost lift from armor/winch.
  5. Apr 21, 2020 at 4:25 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I’ve been running mine 1 clip up for a good 5-6 years now without any issues.
  6. Apr 21, 2020 at 4:35 PM
    brvermilli21
    Knoxville TN
    What springs are you running?
  7. Apr 21, 2020 at 4:44 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I just went out to the garage to double check the PN. 112-620’s which are the 1.6” springs. Not the same spring that you were asking. :oops:
