toytec lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by loganwayne98, Aug 11, 2014.
  1. Aug 11, 2014 at 5:53 PM
    loganwayne98
    loganwayne98 [OP] Member
  2. Aug 14, 2014 at 5:57 PM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    I had something similar but have since changed it. Tacomas are notorious for sagging in the rear. The add a leaf was designed for stock height. (not sagging) So if your rear is sagging then your front may actually sit higher with that lift. If so then get a toytec shackle in addition. An add a leaf also rides pretty rough. Are you doing much wheeling or mostly on pavement?
  3. Aug 16, 2014 at 5:22 PM
    loganwayne98
    mostly highway but a good bit of wheeling too. so ride quality is a big thing for me. mine doesn't sag at all in the rear
