Toytec lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SMG26, Jul 22, 2009.
  1. Jul 22, 2009 at 10:20 PM
    SMG26
    SMG26 [OP] Well-Known Member
    Woodstock,GA
    06 Prerunner TRD Offroad
    Injen CAI, JBA exhaust pipes 2.5" w/magnaflow muffler, Doug Thorley Long tube headers, URD MAF CAL and O2 sim,Access roll up cover, AVS Wind deflectors, coverking seatcovers, grillcraft upper/lower grille, Halo projectors w/6000k HID and pop lock on tailgate.
    I recently bought a 3" toytec spacer lift kit. Will I need the rear shock extenders or is it not really nessecary. Also I live in Georgia and was wondering what is the best place to have it installed. I called my local dealer and they said about $400 w/alignment. Are the dealerships really experienced with lifts. I also checked out 4 wheel parts and they said $330 with out alignment.
  2. Jul 22, 2009 at 10:22 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    you dont have to get new shocks or extenders, i drove for a year with stock shocks on mine.... but it will limit your travel a few inches i believe
    and i would have 4 wheel pars do it and take it to a sears to have aligned, I think they warranty their alignment
  3. Jul 22, 2009 at 10:23 PM
    Kenny650
    Kenny650 Well-Known Member
    You don't need the rear shocks but I would recommend them, especially the rear Bilstein 5100's.
    Don't let the dealer install the lift, your just getting ripped off. I would suggest maybe tackling the install yourself. Just read around the suspension forum on TW and read the "Shock Install/Removal" thread.
  4. Jul 22, 2009 at 10:40 PM
    Trauma85
    Trauma85 Well-Known Member
    Tyler
    Idaho
    2014 Tundra
    Being that I work at a dealership, I see a lot of people that do their own suspension work and end up bringing their truck in with steering complaints or vibrations. If im thinking of the right kit, that one has the strut spacer and the coil spacer, and to do the coil spacer you have to remove the strut, and compress the coil. So you need a spring compressor. The leaf isnt too bad to install, and you will have a fairly short travel in your shocks. You should be fine with the stock shocks, but if you plan on going any higher, you would need a new set, and brake cable extensions. Hope this helps!
    Edit: Either way, make sure you get it aligned.
  5. Jul 22, 2009 at 10:41 PM
    Kenny650
    I don't think extended brake cable's are super necessary if your only lifting 3" or less. Anything over 4" requires new extended brake lines.
  6. Jul 23, 2009 at 6:10 AM
    Trauma85
    Tyler
    Idaho
    2014 Tundra
    If you read my post I told him if he decides to add more than 3" in the futer he will need them.
  7. Jul 23, 2009 at 5:34 PM
    SMG26
    Woodstock,GA
    Thanks for the info guys. Is $400 w/ alignment about a good price for the install.
  8. Jul 23, 2009 at 6:11 PM
    fghtngsquirrel
    fghtngsquirrel Ka-freakin'-BOOM!
    Jacksonville, FL
    '08 4x2 Rad Red *SOLD*
    Two days ago I paid $200 for front C/O's, rear AAL and shocks installed, then $60 for an alignment at Tire Kingdom (6 months free alignments). 4 Wheel Parts quoted me $400 without an alignment.
  9. Jul 23, 2009 at 6:29 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    $400 sounds hella expensive for a spacer lift, even with alignment. Even the coil spacers. take the coilovers off, take them to Pep Boys and have them put them together for $40 or so, then bolt them back on yourself.
  10. Jul 23, 2009 at 6:57 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I just finished doing the spacer lift today, i'm gonna do a thread with pics maybe it will help. I did all the work myself, i just rented the strut compressor at autozone for 50 bucks. part number 27036 i think. then you get your money back when you return it. IT TAKES A WHILE, but you can do it and save your self some money, but probably not time:D
  11. Jul 23, 2009 at 10:00 PM
    Trauma85
    Tyler
    Idaho
    2014 Tundra
    400 Isnt that bad really, a $229 kit, + 2 hours of labor is $389, at hour shop it would be $453 when you add the alignment.
  12. Jul 24, 2009 at 2:51 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Gonna have to agree, the job looks tough, but it's not. I did the one side by myself in 30 min, and I didn't know what I was doing at first.
    Chris4X4 posted a thread on doing/changing it. Came in helpful for me............
  13. Jul 24, 2009 at 9:19 AM
    SMG26
    Woodstock,GA
    I decided too install the lift myself after looking at the replys and researching the forum. I also bought some zinc axel shims. How and where do these need to be installed. Also 285/75/16 do I need wheel spacers on stock trd offroad wheels.
  14. Jul 24, 2009 at 9:22 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  15. Jul 24, 2009 at 9:26 AM
    LonghornTaco
    Minnesota
    Spacers, yes. That's what I'm running.
