ToyTec/OME Ultimate 3" Lift Plus More!
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Mainfraim520, Jan 3, 2013.
  1. Jan 3, 2013 at 10:47 PM
    Mainfraim520
    Mainfraim520 [OP] Member
    Jeff
    Rockford,IL
    99 Black SR5 TRD
    Hi all, I wish I would have joined this forum along time ago! Now unfortunately I have lost my baby due to frame rust perforation. I really, REALLY loved my Tacoma and I refused to take the Toyota buy back money 2 years ago. But back in August I was getting ready to install this lift and as I was scraping the bubbling undercoating from the frame my scraper went straight through. That's when I new it was time for me to make a decision. I stripped everything from the truck that I could, and even swapped the engine into my buddies high mileage '97 4runner before the Taco was crushed. So being the Toyota lover that I am, I decided to pick up an '08 FJ Cruiser Trail Teams edition as a replacement. I now have this complete lift kit lying around taking up space that I cant use, and I would love to see it go to good use on one of your guys trucks. Some parts were installed on the truck for about a week but NEVER driven on, like the front shocks, but most are still brand new. I have over $2000 into this setup but am only asking $1800. I might be willing to part out. I am located in Rockford, Illinois.
    SOLD -Toytec Coil Overs with Bilstein shocks (95.5-04 Tacoma/96-02 4runner)
    -Bilstein 5100 Rear Shocks (95.5-04 Tacoma/86-95 pickup)
    -OME 2 1/4" Lift Rear Springs with Energy suspension bushings in front and wheelers poly bushings in rear (7 leafs with military wraps) (98-04 Tacoma ONLY)
    -Light Racing Adjustable Upper Control Arms (95.5-04 Tacoma/96-02 4runner)
    SOLD -Toytec Front Diff 1" Drop Kit
    -Brake Proportioning Valve Bracket Kit
    -OME Exhaust Drop Bracket Kit
    -OME Greasable Shackles
    -Wheelers Extended U-bolts
    SOLD -Moog Sway Bar End Links with Energy Suspension bushings
    -Energy Suspension Lower Control Arm Bushings
  2. Jan 3, 2013 at 10:53 PM
    Mainfraim520
    Jeff
    Rockford,IL
    99 Black SR5 TRD
    Also, here are pics of the old and the new!
  3. Jan 3, 2013 at 11:38 PM
    marintacoma
    marintacoma Well-Known Member
    San Luis Obispo
    2004 white toyota tacoma 4x4 trd
    coilovers and some shiny wheels
    how much would you sell just the coilovers, or control arms for? shipped to california
  4. Jan 4, 2013 at 9:10 AM
    Jaren1512
    Jaren1512 Well-Known Member
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    Deck plate mod, all chrome plasti dipped, 32" BFGs, fogs, 3" bilstein coilover 5100s/5150s in the rear, manaflow exhaust, smoked tail lights, rooftop lightbar, upgraded alpine sound.
    Id buy the UCA's off you...
  5. Jan 4, 2013 at 9:15 AM
    450rider
    450rider Well-Known Member
    Oregon
    98 4x4 SR5 Maroon
    Leveling Kit, K&N Filter, Rockford Fosgate speakers, mono block amp, 4 channel amp, capacitor, sub and both amp kits and a Pioneer DVD player By-passed
    Sorry for the dumb question but, Would this be everything I would need to lift my truck 3" the right way?
  6. Jan 4, 2013 at 2:37 PM
    Mainfraim520
    Jeff
    Rockford,IL
    99 Black SR5 TRD
    $600 for coil overs and rear shocks. $400 for UCA's. I would need your zip code to calculate shipping cost though.
  7. Jan 4, 2013 at 2:42 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    haha yes, this is about the best way to lift your truck. After this kind of kit you get into high performance mid and long travel kits, but this is still a really good mid travel kit!
  8. Jan 4, 2013 at 2:51 PM
    Mainfraim520
    Jeff
    Rockford,IL
    99 Black SR5 TRD
    The short answer is yes. The best part of doing it this way is the rear leaf springs. Allot of people go the cheap route lifting the rear with an axle spacer or with extended shackles which can create a harsh ride or improper drive line angles. The OME Dakar leaf springs will give you the proper lift height in the rear while providing a very nice enjoyable ride. The front coil overs are adjustable so you can dial in the proper amount of front lift. The diff drop kit will keep your front axles closer to the factory geometry so that you don't blow out cv joints. The adjustable upper control arms correct for camber with the new lifted height preventing the ball joints from binding. And the Energy Suspensions bushings will make the truck ride like new again.
    http://www.toyteclifts.com/index.ph...tegory_id=122&option=com_virtuemart&Itemid=72
  9. Jan 4, 2013 at 4:03 PM
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4 Loaded.
    Stock to the MF airbox.
    How much for the shackles? And how much lift are they?
  10. Jan 4, 2013 at 7:47 PM
    BigStoke
    BigStoke Member
    Stoke
    NorCal
    '99 T4R SR5
    PM Sent
  11. Jan 4, 2013 at 9:31 PM
    Mainfraim520
    Jeff
    Rockford,IL
    99 Black SR5 TRD
    Thanks To Everyone That Has Pm'ed Me. Unfortunately I Work Nights And Am Currently Writing ThIs On My Cell Phone which is Giving Me A VERY hard Time As You Can See! :mad::mad: I Get Off Around 6Am central Time, And I Will Try To Respond To Everyone ThEn. Sorry For The Delay!
  12. Jan 5, 2013 at 1:32 PM
    BigStoke
    BigStoke Member
    Stoke
    NorCal
    '99 T4R SR5
  13. Jan 5, 2013 at 9:45 PM
    BigStoke
    BigStoke Member
    Stoke
    NorCal
    '99 T4R SR5
    Payment sent for coilovers and diff drop.
    Thanks!
  14. Jan 7, 2013 at 6:44 AM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Dakars, 5100's, and u bolts to 27053?
  15. Jan 8, 2013 at 9:35 AM
    Dylla34
    Dylla34 Active Member
    Lemont
    03 TRD Prerunner
    Billy 5100's, Deckplate Mod, Magnaflow exhaust, Throtle body spacer.. , black rims, bull bar with lights and deer whistlers, black spray painted rims, Alpine head unit, Infintiy and alpines all around, and a 10 inch sound ordinance powered sub under passenger seat.
    Main frame. I live in Illinois as well and have 5100's on the front. Can i jack up my front to 2.5 and sit level with those rear leafs ?
  16. Jan 10, 2013 at 5:19 AM
    Mainfraim520
    Jeff
    Rockford,IL
    99 Black SR5 TRD
    I'm not totally sure on that one man, it would be a good question to be answered by one of the senior members on here. I never actually got to lift the truck to see exactly what it would do, but I do know the front coilovers came preset to 3" of lift and ToyTec told me the 2 1/4" rear lift would level out the truck. So I am assuming that with only 2 1/2" of front lift you would maintain some of the factory rake.
  17. Jan 10, 2013 at 9:38 AM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    You would probably still have a little bit of rake but it wouldn't be much at all. The general rule is an inch more of lift in the front over the rear will yield a level truck. So 2.5in out front would call for 1.5-2in out back and it should be close to level. I'm a fan of a level truck and if it helps any I'm looking at going with toytec coilovers set to 2.5in with dakars in the rear.
    Another thing to consider is that your stock springs are probably pretty tired so setting your 5100's at 2.5 may not yield 2.5in of lift. You may only get 2 or so.
    Hope this helps.
  18. Jan 10, 2013 at 9:39 AM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    You can always remove a leaf in the dakars to get less rake
  19. Jan 10, 2013 at 9:41 AM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    ^ This too. You can take one of the overloads out.
  20. Jan 10, 2013 at 12:59 PM
    2k4Taco
    Swanny
    Fleming Island, Fl
    Are the rear leafs still available?
