toytec question??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stampaid4, May 8, 2009.
  1. May 8, 2009 at 2:02 PM
    stampaid4
    stampaid4 [OP] Improvise Adapt Overcome
    i have a 3inch toytec lift on my 06 taco prerunner...my question is how do i give a tad more lift to the front end or a tad less to the rear? the front seems a little lower the rear and i dont like it...
    any help appriciated! thanks:)
  2. May 8, 2009 at 2:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
    Which lift do you have? Spacer? Adjustable?
  3. May 8, 2009 at 2:06 PM
    stampaid4
    thank you!
    im new to toyotas...how can i tell?
  4. May 8, 2009 at 2:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Can you take a picture of the front top of the shock, and the rear springs where it connects to the axel, and post it up?
  5. May 8, 2009 at 2:19 PM
    stampaid4
  6. May 8, 2009 at 3:17 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    Looks like you've got a spacer in the front and a block lift in the rear, You could drop the rear by taking out the block, for the front the easiest / cheapest way to get a little bit of lift is to buy the bilstein 5100 front shocks that allow you to adjust you lift ammount.
  7. May 8, 2009 at 3:25 PM
    stampaid4
    wheres a cheap place to buy those?
    is that wat most people do?
  8. May 8, 2009 at 4:00 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    the quickest/easiest way to give the prerunner look is to remove that rear block. simply adding the 5100's to the front end will DROP the front to a max of 2.5" and thats not what you are asking for. take the block out the rear and it'll drop the ass that much. if u do that, u may also want to look for stock/shorter u-bolts b/c those things will be dragging the ground as long as they are now
  9. May 8, 2009 at 4:02 PM
    stampaid4
    so if i got the 5100's and kept the spacers up front it would actually lower the front??
  10. May 8, 2009 at 4:07 PM
    jhodge83
    SC
    17 XLT Sport
    u can run the spacers w/ the 5100's, but the 5100's have to be set to 0" lift and u'll be getting the exact same lift from the spacers, but a nicer ride on the 5100's.
  11. May 8, 2009 at 4:57 PM
    stampaid4
    wat if i set it to a higher lift tho?
  12. May 8, 2009 at 5:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok...If you remove the block, your gonna need shorter U bolts as there is not enough thread to secure the axel with the blocks removed and those U bolts. Also, 3" lift is about Max you can go with a stock front end. If you want to go higher, your gonna need lift spindles (which start at 3.5" lift) or a drop bracket lift (which starts at 4" lift).
