(toytec)Rear shocks, any suggestions??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mr.Fahrenheit, Oct 27, 2008.
  1. Oct 27, 2008 at 4:40 PM
    Mr.Fahrenheit
    Mr.Fahrenheit [OP] Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    hey tw,
    have a toytec lift in a box waiting to be put on(spacer w/ aal). now the instructions recommend longer rear shocks....any suggestions as to which one i should get? procomp?? auto parts store special??
    i currently have kyb on all four corners.... previous owner put them on... not sure if that matters:rolleyes:
  2. Oct 27, 2008 at 4:55 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    There are some members that don't care for Pro Comp too much. I have had a pair of Pro-Comps on the back of my truck for a year with no problems. I bought them because they were cheap.
  3. Oct 27, 2008 at 5:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    procomps like toy4life will work, as will some ome's and also some bilstein 5125's....a little pricey, but a good shock nonetheless.
  4. Oct 28, 2008 at 2:09 PM
    backwoodking
    backwoodking Well-Known Member
    Thousand Oaks/Southern CA
    3.4 V6 Deck Plate and Cut Turn-Down
    Deck Plate, Hitch, Cut Turn-Down Exhaust, Tint, Clear Corners, Shell, Full Size bed in the pickup, Hopefully More Soon
    If you have the money you should try to go for the proven best...bilstein.
  5. Oct 29, 2008 at 11:26 AM
    SRFIVE
    SRFIVE Well-Known Member
    Upstate NY
    '04 SR5 TRD DC
    My stock ones were overextended at times, I wanted to replace them with Bilsteins too, but they don't make them for 2" lift. I ended up getting the Rancho RS900XL adjustables.
  6. Oct 29, 2008 at 12:29 PM
    Mr.Fahrenheit
    wait so will my stock truck with an aal in the rear...will the bilsteins work or not?? still not sure what to do....have money but unsure if i wanna blow it on really nice shocks for the rear.....
    thanks guys:)
  7. Oct 29, 2008 at 12:33 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    The stock shocks will work, but you only have about an inch of down travel left after you add the the AAL. Alot of people go for the 5100 series billy's or the OME's. You can find them both on toytec's website.
  8. Oct 29, 2008 at 6:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    He will have more than an inch. More like 5 or so.
  9. Oct 29, 2008 at 6:03 PM
    Justin626
    Palmer, Alaska
    With the stock rear shocks?
  10. Oct 29, 2008 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. BUT, the stock shocks will still "Top out" . Keep in mind that the rear suspension has about 12" of travel, or so.
  11. Oct 29, 2008 at 7:41 PM
    Mr.Fahrenheit
    so if i keep the stock shocks, which i wont, they will prevent the suspension from flexing into the bed or away from it?
  12. Oct 29, 2008 at 7:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    from flexing away from.
  13. Oct 30, 2008 at 6:39 AM
    SRFIVE
    Upstate NY
    '04 SR5 TRD DC
    With a 2" AAL in the rear and stock Bilstein shocks, mine overextended at times. An easy test is to lift the truck up by the frame...the shocks will extend to their limit, but the rear springs will still be pushing the rearend down (be under pressure). Pop a shock off and see what happens...the rear end will come down another 2+". So, during articulation the same thing is happening, shock is limiting travel (down). There's a couple 0-2" shocks out there, I choose the Ranchos. The part number is RS999144, with a 14.25" compressed length and 21.875" extended length. The stock Bilsteins (P/N F4-B46-2285 & F4-B46-2286) have travel of 13.6" compressed and 19.8" extended.
