Toytec springs w adjustable billies
Discussion in 'Suspension' started by tc98tacoma, Jan 1, 2011.
  1. Jan 1, 2011 at 7:19 PM
    tc98tacoma
    tc98tacoma [OP] Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    My trucks a 98 the toytec springs are giving me 3 inches of lift I wanna know what I should set the adjustable billies up front to zero or what?? Since I don't need the lift from the billies or do I??any info is great!!!thx
  2. Jan 1, 2011 at 7:27 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    If you are only wanting 3" of lift and you are getting that with them at 0 then leave them there but if you want more just crank em up but remember the higher is goes te roughter that ride will get and the worst the cv angles will be. Might want to look into a Diff drop if you go over 3".
  3. Jan 1, 2011 at 7:30 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    DO NOT set the billies at anything but zero if your springs are already giving you 3". The billy's weren't designed to accommodate anything over 3".
  4. Jan 1, 2011 at 11:30 PM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    what exactly does the diff drop do? im doing a little bit at a time as i build up more money im going to most likely get ucas next unless yall have any ideas what i need from doing this three inch in the front
  5. Jan 2, 2011 at 7:32 AM
    TexasTacoma37
